You can call Film::ExecuteImagePipeline(imagePipelineIndex) in order to run one of the pipelines you have defined and than you can collect the result by calling Film::GetOutput(OUTPUT_RGB_IMAGEPIPELINE,bufferPtr).TAO wrote: Thu Nov 07, 2019 1:21 pm Can you show me any reference to how you do the image pipeline after rendering?
Re: MaxLuxCore - 3ds Max Integration for LuxCore
Here is render.cfg
When i execute pipeline for index 0 its work
But when i use index 1 plugin crash and give me error code for violation access on 0.fffffffffffff
I may miss something again.
renderengine.type = "PATHCPU"
opencl.platform.index = "-1"
opencl.cpu.use = "1"
opencl.gpu.use = "1"
opencl.cpu.workgroup.size = "0"
opencl.gpu.workgroup.size = "0"
opencl.devices.select = "11"
batch.halttime = "0"
film.opencl.enable = "1"
film.opencl.platform = "-1"
film.opencl.device = "-1"
film.imagepipeline.0.0.type = "TONEMAP_AUTOLINEAR"
film.imagepipeline.0.1.type = "TONEMAP_LUXLINEAR"
film.imagepipeline.0.1.sensitivity = "100.0"
film.imagepipeline.0.1.exposure = "2.4"
film.imagepipeline.0.1.fstop = "2.8"
film.imagepipeline.0.2.type = "GAMMA_CORRECTION"
film.imagepipeline.0.2.value = "2.2"
film.imagepipeline.0.2.table.size = "4096"
film.imagepipeline.1.0.type = "INTEL_OIDN"
film.imagepipeline.1.1.type = "TONEMAP_AUTOLINEAR"
film.imagepipeline.1.2.type = "TONEMAP_LUXLINEAR"
film.imagepipeline.1.2.sensitivity = "100.0"
film.imagepipeline.1.2.exposure = "2.4"
film.imagepipeline.1.2.fstop = "2.8"
film.imagepipeline.1.3.type = "GAMMA_CORRECTION"
film.imagepipeline.1.3.value = "2.2"
film.imagepipeline.1.3.table.size = "4096"
film.height = "768"
film.width = "1024"
film.filter.type = "GAUSSIAN"
film.filter.xwidth = "1.000000"
film.filter.ywidth = "1.000000"
film.filter.gaussian.alpha = "0.100000"
lightstrategy.type = "UNIFORM"
sampler.type = "SOBOL"
scene.file = "scene.scn"
session->GetFilm().ExecuteImagePipeline(0);
session->GetFilm().GetOutput<float>(Film::OUTPUT_RGB_IMAGEPIPELINE, pixels);
It is "film.imagepipelines.0.0.type", you are missing an "s". The missing "s" is leading to the second pipeline overwriting the first one. So you ask for a pipeline that doesn't exist and boom.
Sorry to be late, these are some snapshots of the environment variables that i found
i don't know if these are the correct ones or the others .
Thank you so much a1-kh.
I'll going to send you new installer and with new features soo you can test and see if installer work correctlly.
Great, thanks.Dade wrote: Thu Nov 07, 2019 10:44 pm It is "film.imagepipelines.0.0.type", you are missing an "s". The missing "s" is leading to the second pipeline overwriting the first one. So you ask for a pipeline that doesn't exist and boom.
I finished it but, I'm not satisfied with the results especially with depth.
Is there any option with OIDN denoiser so i can optimize it.
Camera Depth Interior Danish Mood Scene
You have strange color "quantization" effect. Can you post the scene in text format (i.e. .cfg, .scn, .ply, etc.) so I can try here and check what is going onTAO wrote: Sun Nov 10, 2019 1:15 pm I finished it but, I'm not satisfied with the results especially with depth.
Yes about the color, i have some questions, please check the scene first.Dade wrote: Sun Nov 10, 2019 1:49 pmYou have strange color "quantization" effect. Can you post the scene in text format (i.e. .cfg, .scn, .ply, etc.) so I can try here and check what is going onTAO wrote: Sun Nov 10, 2019 1:15 pm I finished it but, I'm not satisfied with the results especially with depth.
Also if the camera changes the distance all light power will be effected and the renderer will get different results.
Everythings are same and only change is camera distance to objects.
I think something's wrong with  , it should'nt be like this.
scene.materials.Material_25.id = 6,728,256Omid Ghotbi (TAO)
You may have a problem with C locale, "." Vs. "," and other nation/language related stuff.TAO wrote: Sun Nov 10, 2019 9:06 pm I think something's wrong with, it should'nt be like this.Code: Select all
