Page 1 of 4
Compiling rules: when should it happen?
Posted: Wed Feb 07, 2018 3:16 pm
by marcatore
Today I had a bit of free time for testing.
One question: compiling kernels should happen everytime I enable a new render feature? For example I create a new material type I've never created before or I had a sky texture and so on.
I'm asking this because I've launched some F12 render and sometimes I had to wait the compiling kernel time before see something but I didn't understood why.
Re: Compiling rules: when should it happen?
Posted: Wed Feb 07, 2018 3:28 pm
marcatore wrote: Wed Feb 07, 2018 3:16 pm Today I had a bit of free time for testing.
Yes but it is even a bit worse: not only when you use a new feature but also when you change a parameter of some feature.
For instance , this LuxCore log line with the kernel symbol definitions:
[LuxCore][1.250] [PathOCLBaseRenderThread::0] Defined symbols: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D RENDER_ENGINE_PATHOCL -D PARAM_RAY_EPSILON_MIN=1.000000e-05f -D PARAM_RAY_EPSILON_MAX=1.000000e-01f -D PARAM_LIGHT_WORLD_RADIUS_SCALE=1.050000e+00f -D PARAM_ACCEL_BVH -D PARAM_FILM_RADIANCE_GROUP_0 -D PARAM_FILM_RADIANCE_GROUP_COUNT=1 -D PARAM_FILM_CHANNELS_HAS_CONVERGENCE -D PARAM_ENABLE_TEX_CONST_FLOAT -D PARAM_ENABLE_TEX_CONST_FLOAT3 -D PARAM_ENABLE_TEX_IMAGEMAP -D PARAM_ENABLE_TEX_NORMALMAP -D PARAM_ENABLE_TEX_FRESNELCOLOR -D PARAM_ENABLE_TEX_FRESNELCONST -D PARAM_ENABLE_MAT_MATTE -D PARAM_ENABLE_MAT_MIRROR -D PARAM_CAMERA_TYPE=0 -D PARAM_HAS_SKYLIGHT2 -D PARAM_HAS_ENVLIGHTS -D PARAM_MAX_PATH_DEPTH=3 -D PARAM_MAX_PATH_DEPTH_DIFFUSE=3 -D PARAM_MAX_PATH_DEPTH_GLOSSY=3 -D PARAM_MAX_PATH_DEPTH_SPECULAR=3 -D PARAM_RR_DEPTH=5 -D PARAM_RR_CAP=5.000000e-01f -D PARAM_SQRT_VARIANCE_CLAMP_MAX_VALUE=8.000000e+00f -D PARAM_IMAGE_FILTER_TYPE=5 -D PARAM_IMAGE_FILTER_WIDTH_X=2.000000e+00f -D PARAM_IMAGE_FILTER_WIDTH_Y=2.000000e+00f -D PARAM_IMAGE_FILTER_PIXEL_WIDTH_X=1 -D PARAM_IMAGE_FILTER_PIXEL_WIDTH_Y=1 -D PARAM_SAMPLER_TYPE=2 -D PARAM_SAMPLER_SOBOL_STARTOFFSET=32
There is stuff like "PARAM_ENABLE_MAT_MATTE" so a compilation will be triggered when you use a Matte material for the first time but there is also "PARAM_MAX_PATH_DEPTH=3" so any time you change the path tracing max. depth, a new kernel compilation will be required.
Any change in the above line will trigger a compilation (i.e. you have to factor all possibile combination of all possible parameters !).
Over the time I have greatly reduced the number of parameters, in particular, I'm trying to remove all parameters like PARAM_MAX_PATH_DEPTH or PARAM_RAY_EPSILON_MAX, etc. (the one that can have an infinite number of values).
Posted: Wed Feb 07, 2018 3:36 pm
by marcatore
ok. understood.
I don't know how much I can ask but , in my PC, every recompiling needs me more than 15 minutes. So if it's a correct recompiling time, it's a bit difficult to use.
If my recompiling time is correct I hope that something will be done to reduce this.
Posted: Wed Feb 07, 2018 3:49 pm
by jensverwiebe
marcatore wrote: Wed Feb 07, 2018 3:36 pm ok. understood.
Aaaah damn... still those long compile times with Nvidia ?
Try to avoid procedurals atm..
There shoulld be a solution, for i have way shorter kernel compile times with other renderers ( ocl ).
Perhaps again some voodoo trick ?
@Dade: the way slower kernel compile on NVidia jumped in with cuda/ocl 8 drivers if i remeber right. ( linux >345.xx driver ).
Perhaps that hints to some change in NV api.
Jens
Posted: Wed Feb 07, 2018 3:54 pm
There's the option to have some features always enabled, this is code from LuxBlend:
enabled_features = (
    'MATTE ROUGHMATTE MATTETRANSLUCENT ROUGHMATTETRANSLUCENT'
    'GLOSSY2 GLOSSYTRANSLUCENT'
    'GLASS ARCHGLASS ROUGHGLASS'
    'MIRROR METAL2'
    'HOMOGENEOUS_VOL CLEAR_VOL'
    'IMAGEMAPS_BYTE_FORMA TIMAGEMAPS_HALF_FORMA TIMAGEMAPS_1xCHANNELS IMAGEMAPS_3xCHANNELS'
    'HAS_BUMPMAPS'
self.properties.Set(pyluxcore.Property('opencl.code.alwaysenabled', enabled_features))
I did not have the time to add this to the new addon yet.
In LuxBlend it was only used for viewport renders, but I guess it would be good to also have it as an option for final renders (in cases where they are not so final, e.g. test renders).
Posted: Wed Feb 07, 2018 4:06 pm
by marcatore
My VGA is a Quadro K5200 and the CPU is an intel Xeon E5 v3 @3.5Ghz with 16GB.
At the moment I have a very few basic material like matte, one glass, one metal.
Area lights with IES file, a Sun light + Sky background.
About the viewport preview I have to admit that it's quick to start. Just 1 or 2 seconds. the problem is only for the F12 render
Posted: Wed Feb 07, 2018 4:10 pm
marcatore wrote: Wed Feb 07, 2018 3:36 pm I don't know how much I can ask but , in my PC, every recompiling needs me more than 15 minutes. So if it's a correct recompiling time, it's a bit difficult to use.
As Jens wrote, this is mostly an NVIDIA problem because their compiler is insanely slow. As general workaround, just use the CPU for editing/pre-view and the GPU only for final render.
The 2 most "deadly" factors for NVIDIA compiler (and in general) are:
- procedural textures;
- recursive materials and textures (i.e. textures referencing other textures like scale, mix, etc.)
Anyway, I will continue in the effort to reduce the number of compilation.
P.S. B.Y.O.B. post is also another aspect to factor.
Posted: Wed Feb 07, 2018 4:11 pm
marcatore wrote: Wed Feb 07, 2018 4:06 pm At the moment I have a very few basic material like matte, one glass, one metal.
Mmm, 15 minutes for that kind of scene sound a bit too much even for NVIDIA compiler :?:
Posted: Wed Feb 07, 2018 4:17 pm
marcatore wrote: Wed Feb 07, 2018 4:06 pm About the viewport preview I have to admit that it's quick to start. Just 1 or 2 seconds. the problem is only for the F12 render
Currently the viewport is CPU-only (no OpenCL involved).
With RTPATHOCL you would moan a lot :P
Posted: Wed Feb 07, 2018 4:38 pm
by marcatore
B.Y.O.B. wrote: Wed Feb 07, 2018 4:17 pm Currently the viewport is CPU-only (no OpenCL involved).
Eheheh...There is always a good reason for everything :)
