Pyluxcoretool exe not working on Windows
Posted: Mon Feb 11, 2019 9:01 am
Hi, I'm getting this error when running pyluxcoretool.exe from recent Windows builds:
I am not 100% sure if it's a local problem of mine: is there any Windows user that could please check if network rendering is working with the latest build?
Otherwise, it must be a problem either in PyInstaller or in the latest PySide2 version, 5.12.1 and I'll set automated builds to use the previous PySide2 version until I find a solution.
Exception: [Errno 2] No such file or directory: 'C:\\support\\signature\\loader.py'
File "pyscript", line 23, in bootstrap
FileNotFoundError: [Errno 2] No such file or directory: 'C:\\support\\signature\\loader.py'
AttributeError: module 'signature_loader' has no attribute 'pyside_type_init'
SystemError: could not initialize part 2
During handling of the above exception, another exception occurred:
File "site-packages\PyInstaller\loader\rthooks\pyi_rth_pkgres.py", line 11, in <module>
File "<frozen importlib._bootstrap>", line 968, in _find_and_load
File "<frozen importlib._bootstrap>", line 957, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
File "c:\hostedtoolcache\windows\python\3.5.4\x64\lib\site-packages\PyInstaller\loader\pyimod03_importers.py", line 627, in exec_module
File "site-packages\pkg_resources\__init__.py", line 33, in <module>
File "platform.py", line 117, in <module>
File "subprocess.py", line 50, in <module>
File "signal.py", line 45, in <module>
File "c:\hostedtoolcache\windows\python\3.5.4\x64\lib\functools.py", line 60, in update_wrapper
SystemError: <method-wrapper '__get__' of getset_descriptor object at 0x000000000012A900> returned a result with an error set
[5100] Failed to execute script pyi_rth_pkgresOtherwise, it must be a problem either in PyInstaller or in the latest PySide2 version, 5.12.1 and I'll set automated builds to use the previous PySide2 version until I find a solution.
