Page 37 of 92
Re: BlendLuxCore Development
Posted: Tue Jul 24, 2018 8:06 am
marcatore wrote: ↑Tue Jul 24, 2018 7:52 am
more modes like ping-pong and a reverse mode, do you think it's doable ??
Yes, it's possible to add these, good ideas.
I just emulated the way Cycles does image sequences, but I have to say I don't find it very intuitive to use.
So if I stray from the path and add ping-pong/reverse, maybe I should improve the user experience as well.
Posted: Tue Jul 24, 2018 10:39 am
great features but don't really understand how you manage to have image auto change without a video file as input
Posted: Tue Jul 24, 2018 12:34 pm
An image sequence is a series of images named "image001.png", "image002.png", "image003.png" etc.
Depending on the current frame in Blender, one of the images is chosen. For example, if we are on frame 2, we pick "image002.png".
That the images "auto-update" is actually an illusion.
On every frame change, the LuxCore session is destroyed and re-created. It just happens very fast.
When the session is created, the image from the sequence is chosen according to the current frame in Blender.
Actually it would not even work with a video file, because LuxCore does not support them.
You have to extract the frames from a video as single images to use them as image sequence.
Posted: Sat Jul 28, 2018 7:15 pm
Shared meshes (Alt+D copies) are now exported as instances when possible.
This makes the export faster and RAM usage lower in scenes that make use of them (e.g. the
SSS dragons).
Note: it is not possible to instance the mesh if any mesh-deforming modifiers are used on the object.
Meaning any modifier not from this list: "COLLISION", "PARTICLE_INSTANCE", "PARTICLE_SYSTEM", "SMOKE"
Posted: Sat Jul 28, 2018 11:12 pm
B.Y.O.B. wrote: ↑Sat Jul 28, 2018 7:15 pm
SSS dragons).
Hmmm this is a nice improvement i've a very very huge scene with lot of building duplicating through alt+D but is an office job already done under Cycles (for workflow and compatibility purposes with other workstation ).
Posted: Tue Aug 07, 2018 11:53 am
SSS dragons).
Does this work in the 2.1 alpha 2? I made some "alt+d" copies but a handful of trees didn't fit into 32GB ram, now I'm not sure if the feature isn't in the version I'm using or how to make instances....
Posted: Tue Aug 07, 2018 11:56 am
v2.1alpha2 was released on 2018-06-29.
My post is from 2018-07-28 (about one month later).
So no, you will have to wait for the next alpha release.
However, v2.1alpha2 supports instancing via groups, particles or duplis.
E.g. add your object to a group with Ctrl+G, then Shift+A -> Group Instance -> your group.
Posted: Tue Aug 07, 2018 12:02 pm
B.Y.O.B. wrote: ↑Tue Aug 07, 2018 11:56 am
Oh I see. Thanks for the help. Are there any timeframes or schedules I can check to see when certain releases are planned?
Posted: Tue Aug 07, 2018 12:13 pm
lacilaci wrote: ↑Tue Aug 07, 2018 12:02 pm
No, all you can currently do is look at the dates of the releases we did so far (in the news section) and try to estimate our release cycle from the mean time difference or something
But because it's been over a month since the last release, I'd like to make one today, if possible.
Posted: Tue Aug 07, 2018 12:17 pm
B.Y.O.B. wrote: ↑Tue Aug 07, 2018 12:13 pm
That sounds great... cause I'm clearly failing somehow to make instances from groups (still fills up ram)...
