Struggling with LuxCoreGUI
Posted: Mon Jan 21, 2019 9:02 pm
When testing Mac versions or the new Photon cache it's mostly done within LuxCore stand-alone.
I have quite some problems to work with that probably because I don't know enough about it.
It starts when opening a cfg file from an empty render window.
Though therein is always a film size specified, LuxCoreGui ignores this, remains with its default size and opens some oddly cropped version of the scene.
Apparently this is the Camera Edit mode it always starts with and has to be switched to image view manually.
When doing so, neither the specified size from the file nor the window size is taken but another default setting from the film tab.
Do I really have to go there and manually type the size in I want to render (and had already set when exporting the text file)?
Especially when trying to test the photon cache with high photon count the GUI is not responding till the cache is done and starts again after each change to the window which I need to do three times until I get my preferred film size...
Another thing: Apparently I can't disable the CPU when doing OCL-rendering.
There is an OCL-devices window where the CPU can be switched off but it has no effect, statistics show all all CPU-threads continue to render.
In the render engine I can reduce the native devices to 1 but not zero.
There is a sampler tab to change the sampler which works.
Then there is the engine tab to change the render engine which it does but it changes the sampler too!
Also the render engine window behaves weirdly, when changing the engine there it immediately restarts instead of waiting till I have changed the parameters and clicked the apply button.
And I cannot find any way to change tone-mapping, gamma or else; there is an image-pipeline window but there can apparently only be switched btween predefined pipelines but not the parameters.
Is there a manual somewhere for the stand-alone that goes beyond the integrated help?
