Weird mix material behaviour
Posted: Mon Jan 21, 2019 7:33 pm
by wasd
Matte material without mix node
Mix node, 100% matte material
When using mix node with any translucent material I get this very unexpected behaviour (like on the second image).
When mixing with non-translucent I get no unexpected um... unexpectedness (like the first image).
You have to add some hdr as lighting.
edit: There should be certain angle of direct light, so I've added the second file with sun lamp
weird_mix2.zip
(483.11 KiB) Downloaded 159 times
Re: Weird mix material behaviour
Posted: Mon Jan 21, 2019 7:40 pm
Does it also happen if you render on CPU?
I remember there was some difference between OpenCL and CPU regarding transparent materials + mix material.
Posted: Mon Jan 21, 2019 7:42 pm
by wasd
B.Y.O.B. wrote: Mon Jan 21, 2019 7:40 pm Does it also happen if you render on CPU?
I only render on CPU, so yes, it happens when I render on CPU.
Posted: Mon Jan 21, 2019 7:52 pm
My bad, sorry, I read "RT Path OCL" in your screenshot for some reason.
