Page 101 of 109
Re: PhotonGI cache
Posted: Fri Jul 26, 2019 9:44 pm
by Racleborg
The only crashes I seem to be having with PGI is when trying to re-work an old scene (which is probably already a mess due to my learning curve), and then swapping an old MATTE node with the new Disney appears to fix it.
Otherwise it feels like working with an ant on speed!
Re: PhotonGI cache
Posted: Sat Jul 27, 2019 8:42 am
Racleborg wrote: ↑Fri Jul 26, 2019 9:44 pm
Sounds weird, can you post the scene (possibly simplified while still reproducing the crash)?
Re: PhotonGI cache
Posted: Sat Jul 27, 2019 5:44 pm
by Racleborg
by B.Y.O.B. » Sat Jul 27, 2019 9:42 am
Racleborg wrote: ↑
Fri Jul 26, 2019 10:44 pm
I think I've already updated those scenes, but I'll look through the archives and try and find one that is still faulty.
Re: PhotonGI cache
Posted: Tue Jul 30, 2019 9:07 am
by marcatore
@Dade
is there some rules to follow to have the best results fomr the PGI?
For example I'm doing
some tests trying to understand how to reduce/remove noise from that part of the scene.
A mirror material should still has the "use photon GI2 option enabled?
Is a particles sytem used for carpet something like to exclude from the PGI?
Re: PhotonGI cache
Posted: Tue Jul 30, 2019 9:43 am
marcatore wrote: ↑Tue Jul 30, 2019 9:07 am
PGI cache is never enabled on specular materials (mirror and glass) so it doesn't matter (probably BlendLuxCore should no show the flag at all for specular materials or show a explanation label).
Only if you need to save memory otherwise you can just use the default settings.
Re: PhotonGI cache
Posted: Wed Jul 31, 2019 5:05 pm
by Racleborg
This is also from an old scene (December 2018)and is creating a different error than the one mentioned earlier ‘Matte to Disney shader fix’. I hope it’s of some help. (Scene link and message attached)
I would have created a new post for this in User Support but I can't see the option for that any more?
https://1drv.ms/u/s!AhdwgLaw01tLnj0lJ5MKC9dlePOC
Thank you
Re: PhotonGI cache
Posted: Wed Jul 31, 2019 7:08 pm
Racleborg wrote: ↑Wed Jul 31, 2019 5:05 pm
Thank you
Are you using a persistent cache file written with another version ? It looks like you are reading some kind of binary LuxCore file saved with a different version, or mixing different types of LuxCore binary files
Re: PhotonGI cache
Posted: Wed Jul 31, 2019 7:29 pm
by Racleborg
Yes, I think by the way in which I've been re-working old scenes, that is probably what I've inadvertently been doing.
Thank you
Re: PhotonGI cache
Posted: Wed Jul 31, 2019 8:28 pm
by Racleborg
I've deleted the old Untitled.PGI file and also tried switching OFF PGI but am now getting a new message with the same scene (attached)
Thanks
Re: PhotonGI cache
Posted: Wed Jul 31, 2019 8:37 pm
Can you post the console output? It should contain some traceback about the error.
