Adding Bump and Normal maps together
Posted: Wed Jan 09, 2019 12:23 pm
by Racleborg
Hi
What is the correct way to add a Bump and a Normal map together?
Is the method in the attached image correct?
Thank you
Re: Adding Bump and Normal maps together
Posted: Wed Jan 09, 2019 12:49 pm
Racleborg wrote: Wed Jan 09, 2019 12:23 pm
Yes. The actual math is more complicated, but LuxCore does that in the background for you (the add texture contains the necessary code and it is used if the output is a bump map).
Posted: Wed Jan 09, 2019 12:50 pm
by Racleborg
@B.Y.O.B
Many thanks
