Duplicated objects
Posted: Wed Dec 26, 2018 10:51 pm
by wasd
That brick sticking out of the wall is child object, which is duplicated with parent object's option "Duplication - Faces".
Is it possible not to render that base object? I exclude layer with the brick from rendering, but it still casting shadow.
Re: Duplicated objects
Posted: Fri Dec 28, 2018 4:27 pm
wasd wrote: Wed Dec 26, 2018 10:51 pm I exclude layer with the brick from rendering, but it still casting shadow.
Uh, this is very strange, can you post a test scene ?
Posted: Fri Dec 28, 2018 8:20 pm
by wasd
Dade wrote: Fri Dec 28, 2018 4:27 pm
Posted: Fri Dec 28, 2018 9:21 pm
Looks like a bug in the Blender addon.
I found that as a temporary workaround, you can hide the duplicator by disabling the render visibility (in the outliner).
Obviously this is not how it should work in Blender, it's a regression in the addon. I'll try to fix it.
Don't exclude the layer through render layers, this is a different functionality (it makes all objects on excluded layers invisible to the camera only).
Posted: Fri Dec 28, 2018 10:36 pm
