Analog film simulation .crf file
Posted: Sun Dec 09, 2018 3:43 pm
by Fox
How do i format the camera response func.file?
Like so:
static float Advantix_100CDRed_I[] = { value, value };
static float Advantix_100CDRed_B[] = { value, value };
static float Advantix_100CDGreen_I[] = { value, value };
static float Advantix_100CDGreen_B[] = { value, value };
static float Advantix_100CDBlue_I[] = { value, value };
static float Advantix_100CDBlue_B[] = { value, value };
Or like the dorfCurves.txt file is formatted:
agfacolor-futura-100CDRed
graph-log-log-neg
I =
value   value
B =
value   value
agfacolor-futura-100CDGreen
graph-log-log-neg
I =
value   value
B =
value   value
agfacolor-futura-100CDBlue
graph-log-log-neg
I =
value   value
B =
value   value
I was mixing the agfachrome-rsx2-200CD and agfacolor-vista-100 and i see all the I = values are identical between this 2 films.
Only B = values are different.
Can i then copy from luxcoreblend spi1d files the 1024 values of R, G and B and put them in crf file on B = lines. The I = line i keep original.
I'd like to make the kodak_dscs_3155.spi1d or canon_optura_981114.spi1d for luxcore.
Re: Analog film simulation .crf file
Posted: Sun Dec 09, 2018 4:28 pm
The code for parsing the file is here: https://github.com/LuxCoreRender/LuxCor ... e.cpp#L327
Each "I" input color is mapped in a "B" output color. Values are form 0.0 to 1.0. So, for instance, you can map red 0.1 in red 0.13 by using a I=0.1 and B=0.13 entry.
Mixing two tables (aka colors) may be not trivial but the first step could be just use the average the 2 "B" values for each corresponding "I" entry.
Posted: Sun Dec 09, 2018 6:51 pm
by Fox
:) Got the external .crf working.
The dorfCurves.txt type formation works.
Only the blender exporter wont copy the crf file to exported scene 00000 folder.
It links the drive address that you set in luxcoreblend.
Works both ways, with name or address in render.cfg file.
kodak-dscs-3155.zip
(19.19 KiB) Downloaded 349 times
Posted: Sun Dec 09, 2018 7:05 pm
Fox wrote: Sun Dec 09, 2018 6:51 pm :) Got the external .crf working.
This is somewhat a bug, I'm going to fix it.
