Advanced Settings Epsilon Value
Posted: Sun Dec 02, 2018 1:56 pm
by Racleborg
Hi
I understand that reducing the Advanced Settings Epsilon value to .0001, from .00001, can help reduce artifacts when previewing.
Does it also effect things such as the Clamp Values and the main render?
Thanks
Re: Advanced Settings Epsilon Value
Posted: Sun Dec 02, 2018 2:16 pm
I think you mean "increasing".
Racleborg wrote: Sun Dec 02, 2018 1:56 pmDoes it also effect things such as the Clamp Values
No. The epsilon is mostly used in ray-triangle intersection tests.
Yes.
Posted: Sun Dec 02, 2018 2:23 pm
by Racleborg
Increasing-yes
If it effects the main render, then I'll play safe and leave it at default. (It does say 'Advanced' settings and I'm definitely not an advanced user!
Posted: Sun Dec 02, 2018 2:38 pm
If you only need to change it because of the ortho viewport render, I would indeed leave it at the default.
But if you notice self-intersection artifacts in perspective mode, you should change it.
This setting can get you in unexpected ways, for example it can make SSS look completely wrong when min. epsilon is set too high.
Posted: Sun Dec 02, 2018 2:41 pm
by Racleborg
Thank you.
