Lux Render sample not rendering correctly
Posted: Fri Nov 16, 2018 10:37 pm
by checoimg
Hi everyone, I'm a noob checking out this renderer. I'm trying to render the samples but one crashes blender and the other doesn't render correctly.
https://pasteboard.co/HNuIl3X.png
Re: Lux Render sample not rendering correctly
Posted: Fri Nov 16, 2018 11:59 pm
Are you using v2.0 to load these?
The example scenes were made with the v2.1 dev versions, so you will need the latest v2.1beta2 to render them correctly.
I have added a note to the download page.
Posted: Sat Nov 17, 2018 10:52 am
by checoimg
Posted: Sat Nov 17, 2018 10:59 am
The warning icon just says that this is an experimental version (alpha/beta).
Does rendering work after you restart Blender?
Posted: Sat Nov 17, 2018 11:30 am
by checoimg
the problem seems to be the "embree.dll" is not named correctly to "embree3.dll"
https://pasteboard.co/HNzLUCS.png
reference post
viewtopic.php?t=403
Posted: Sat Nov 17, 2018 11:40 am
Ah yes this is a known (and unsolvable) problem.
You can't use the updater in v2.0 to update to v2.1.
You will have to remove the old addon first, then install the new one from the zip.
This is also mentioned in the "How to update" section of the installation instructions:
https://wiki.luxcorerender.org/BlendLux ... stallation
Posted: Sat Nov 17, 2018 11:45 am
by checoimg
Where do I get 2.1?
Posted: Sat Nov 17, 2018 12:51 pm
by checoimg
Thanks so much! I'm leaving the installation wiki here
https://wiki.luxcorerender.org/BlendLux ... rs_of_v2.0
Here's my render
https://pasteboard.co/HNAiVeV.png 1500 samples, 53:29
