I have a problem to install 2.1alpha4
Posted: Tue Oct 23, 2018 7:50 am
by BigGoga
I can not understand what to do.
Re: I have a problem to install 2.1alpha4
Posted: Tue Oct 23, 2018 9:18 am
BigGoga wrote: Tue Oct 23, 2018 7:50 am
Have you installed the libraries listed at the end of the message
viewtopic.php?f=9&t=630 ?
Posted: Tue Oct 23, 2018 9:21 am
by BigGoga
Yes.
I installed these packages.
Posted: Tue Oct 23, 2018 9:28 am
BigGoga wrote: Tue Oct 23, 2018 9:21 am
Yes.
Are you using the OpenCL version ? Is LuxMark working ?
Posted: Tue Oct 23, 2018 9:32 am
Are you using Blender 2.79b or a different version?
Posted: Tue Oct 23, 2018 9:46 am
by BigGoga
I'm using version Blender 2.79b from blender.org
Posted: Tue Oct 23, 2018 10:04 am
by BigGoga
Dade wrote: Tue Oct 23, 2018 9:28 am
I tried to install version with OpenCL version and version without OpenCL
Yes. LuxMark is working.
Posted: Tue Oct 23, 2018 10:28 am
BigGoga wrote: Tue Oct 23, 2018 10:04 am
Ok, you will have to investigate what DLL you are missing. Download the stand alone version from
https://github.com/LuxCoreRender/LuxCor ... opencl.zip
Unpack the .zip and run the luxcoreui.exe, you should get an error (post the message here, please).
You can than use a tool named Dependecy Walker to check what DLL you are missing, the procedure is described here:
viewtopic.php?f=4&t=640&p=6412&hilit=de ... lker#p6407
Posted: Tue Oct 23, 2018 10:53 am
by BigGoga
When I launch LuxCore UI there is no error.
after checking "luxcoreui" with dependencywalker
Posted: Tue Oct 23, 2018 11:48 am
BigGoga wrote: Tue Oct 23, 2018 10:53 am
This mean the problem is python related. Are you sure to use the official Blender 2.79b (Python v3.5) and not a daily build or v2.80 (Python v3.6) ?
