Help Blender crash on startup
Posted: Sat Oct 20, 2018 10:26 pm
Hi guys ! need you help i've a project to finish before monday and Blender start to have strange behaviour (Blender 2.79b / blender 2.78c crash on startup). Blender 2.8 work / Computer can run some heavy game like project cars without problem. I'd also clean up Graphique driver with amd clean up utility and reinstall new driver wich work fine with other 3D application. After some research over the web i also try to launch blender through commande line and this is the output:
Re: Help Blender crash on startup
Posted: Sat Oct 20, 2018 11:17 pm
You could try to rename your addon folder:
viewtopic.php?f=4&t=622&p=6340#p6334
Maybe one of your installed addons causes the crash.
Posted: Sun Oct 21, 2018 1:45 am
Finally i've done a w10 reset. and blender work but all gpu render now take a while (veryyy loong kernel compilation time, never ending so i kill blender process)
Posted: Sun Oct 21, 2018 2:09 am
delete alpha4 for Alpha3. but alpha3 can't read shader done under alpha4.
Posted: Sun Oct 21, 2018 2:19 am
by alpistinho
Sharlybg wrote: Sun Oct 21, 2018 1:45 am
I believe this sounds like as if you are using the default GPU drivers. Have you installed those again?
Posted: Sun Oct 21, 2018 2:36 am
After uninstall and install process between Blendluxcore A4 and A3, Alpha4 seem to work now. But will continue to work to see what happen !
