POLL - v2.11 Development Priorities
Posted: Mon Jun 23, 2025 8:10 am
Hi everyone,
This is the poll for new feature priorities, based on the previously collected ideas in this thread:
viewtopic.php?t=6667
We have decided to not put each individual feature up in the poll directly, but rather group items in a few categories. A feedback in which direction we should focus our attention presently makes more sense in our view.
Below, you find a more detailed description with examples which suggested features fall into that category:
Improve performance of existing features
You can pick up to three options.
Votes can be changed before the end of the poll.
Best wishes,
The LuxCoreRender Team
- For currently implemented features, e.g. materials or textures: Perform timing analysis, determine potential for improvements, then do some optimisations
- Examples: GPU support for OIDN, multithreading in shape algorithms (subdiv, displace, simplify…), vectorization (SSE/AVX) in elementary operations (points, vectors…) for eligible platforms, precompiled GPU kernels
- Improve the feature set of existing materials and textures.
- Examples: Disney material upgrade, support more Cycles textures, color space support
- Adding completely new materials and models.
- Examples: Autodesk standard surface, new microfacet models, new Sky models
- Changes to the engines. Not affecting materials, but how the ray tracing is executed.
- Examples: Path guiding, Spectral rendering, camera models, light linking
- Features that change or improve the way geometry is handled and support for file exchange formats
- Examples: Alembic, USD, Adaptive subdivision, remeshing, smoothing, hole filling, cryptomatte
- Improving the performance of the Blender addon. Additionall,y There are some features available in LuxCore that are not exposed in BlendLuxCore.
- Examples: Improve export times, viewport response times. BakeCPU, BidirVM, user-defined sampling, russian-roulette, normalmap.
- Replace the existing LuxCoreUI, written in C++, by a new Python implementation.
- Use smart pointers instead of raw pointers, remove Blender dependency from luxcore.so (keep it only in BLC), reduce compile time, apply linter, fill documentation gaps
Best wishes,
