Questions about ViewLayers and Holdout in Blender (4.2.9 LTS) with BlendLuxCore v2.10-alpha2
Posted: Fri May 02, 2025 10:23 am
by mazadak_
Hello. As the title suggests, I have some questions to which I couldn't find an answer to. I am relatively new to LuxCore, coming from Cycles. I do some VFX work, and decided to switch because of LuxCore's built in realism. Now I need some help finding a way of rendering, as an example, a shadow pass as its own Layer. I know how to set up a shadow catcher, and I know all the other bits as they directly translate from Cylces to LuxCore. Everything, except Holdouts for ViewLayer (the layer with my object) and ViewLayer_001 (the layer with the shadow catcher). I want to have both objects in my layers, but only one visible at a time. My LuxCore keeps crashing when I do that (rendering on an MX550 2GB with CUDA-backend). I've found the "Holdout" option in the material settings, but it's like disabling one layer, rendering the other and switching manually. This is possible, but my renders take long and I'd like to just leave it overnight doing its thing automatically, rather than trying to catch the perfect time to start the second layer. Any help highly appreciated.
Re: Questions about ViewLayers and Holdout in Blender (4.2.9 LTS) with BlendLuxCore v2.10-alpha2
Posted: Sat May 03, 2025 8:53 am
by CodeHD
Hello,
Can you provide a (simple) test scene in the form of a .blend-file that produces a crash for you?
This is needed to determine if it is hardware specific, or due to some particular settings.
It will also help to understand what exactly you are trying to achieve as a resulting image.
Posted: Tue May 06, 2025 11:13 am
by mazadak_
Here's the requested sample scene.
Posted: Tue May 06, 2025 7:31 pm
by CodeHD
Thanks.
Now that I run the scene, I relaize I could have spotted the issue from the title...
There was an Issue with ViewLayers that got fixed with v2.10.0-rc.1
I tested your example scene and it seems to work fine here.
I suggest you test the new rc-version as well:
https://github.com/LuxCoreRender/BlendL ... .10.0-rc.1
Posted: Fri Jul 11, 2025 5:44 pm
by mazadak_
Hey there, I know it's been quite a long time since your answer but unfortunately I can't seem to solve the issue still. I'm using LuxCoreRender's 2.10.0 stable release now but Holdouts still don't work. I might be doing something wrong and I apologise in advance if it truly is a stupid mistake on my side that I haven't realised. Any further help would be greatly appreciated.
Posted: Sat Jul 12, 2025 8:42 pm
by CodeHD
Over the original crash issue and the existing code regression at the time, I didn't fully consider what you were trying to achieve in terms of visibility at a time.
At first glance that also doesn't work for me, but I would have to look at that in greater detail at some point, comparing existing documentation for BlendLuxCore, what should be implemented already.
Posted: Tue Jul 15, 2025 3:51 pm
Seems strange, because on a new scene holdout works as expected.
Or am I doing it wrong :?
RndrVwLyrs_BLC210_4212RC.blend
(173.19 KiB) Downloaded 14093 times
