Solar panel
Posted: Wed Aug 15, 2018 1:36 pm
Made a solar panel material in Substance designer and rendered in LuxCore.
I just used default metal/rough.FarbigeWelt wrote: Thu Aug 16, 2018 6:46 am How to you export to luxcore for rendering? Substance Designer does not mention it.
Yes, I first create a tiling texture and then apply it to my objects. If you're interested in a simpler solution for making tiling textures check out allegorithmic's bitmap2material. But you could just do it manually in Krita.FarbigeWelt wrote: Fri Aug 17, 2018 6:17 am This means, you create tiling textures first, and import them to blender adding then materials in luxcore addon?
Do you know other tiling texture creating software?
Thank you for the hint, looks like Wrap-around mode is exactly what I was looking for.
