Suggested Clamp Values
Posted: Mon Jul 30, 2018 12:55 pm
by Racleborg
Hi All
With interiors, is there a general rule to aim for with the Suggested Clamp Values?
Are values around 200-300 regarded as acceptable, or is this a bit too high?
I usually aim to keep them under about 50. Is this restricting myself too much?
Thank you
Re: Suggested Clamp Values
Posted: Mon Jul 30, 2018 1:00 pm
Clamp value depend mostly on the kind of lighting you have in your scene. the brighter the light source the higher the clamp/suggested clamp values will be.
My trick is to have 10X the suggested clamp for interior and try to down it until i loose to much detail.
Posted: Mon Jul 30, 2018 1:20 pm
by Racleborg
Hi Sharlybg
Thank you for your response.
Could you elaborate a bit, please. I'm not quite sure what you mean by:
Sharlybg wrote: Mon Jul 30, 2018 1:00 pm
10X?
(If I could get renders that look half as good as yours I'd be well happy!
Cheers
Posted: Mon Jul 30, 2018 1:32 pm
I have described the procedure here a bit:
https://blenderartists.org/t/motorcycle ... ?u=b.y.o.b
It's also on my to do list to find a better algorithm for suggesting optimal clamp values:
https://github.com/LuxCoreRender/BlendL ... issues/195
However I first have to come up with some testing/validation method (and there is probably never a "perfect method" because what counts as a firefly is depending on the scene a bit).
Posted: Mon Jul 30, 2018 1:42 pm
by Racleborg
Thank you for the link, which has explained it very clearly for me.
Have a nice weekend.
