Irradiance Contour Not Showing on Irradiance, Albedo Layers etc. Not working Properly in Indirect Diffuse Layer etc.
Posted: Fri Jul 15, 2022 1:42 am
by Jan
Is there a way to make Irradiance Contour Lines showing properly on layers other than the Direct Diffuse Layer and according to the brightness values of that layer?
Works properly but those were only Reflected Radiance (light power/area solid angle) values of Direct Diffuse Layer.
Irradiance not displaying properly according to the Reflected Radiance values of Indirect Diffuse Layer. There should be no color coutour lines because values are all zero
No Irradiance Contour Lines despite this is the Irradiance Layer and the values are not zero. This Irradiance layer are values of the Incoming Irradiance on the object surfaces or total incoming light power per area
Using Luxcore v2.4
Diffuse_50% Reflect.blend
(870.38 KiB) Downloaded 1314 times
Thanks!
