Ignore intersecting geometry
Posted: Mon Jun 20, 2022 10:15 am
Any help on this would be greatly appreciated.
I am attaching the image of the problem I am facing. It is not a problem with the render engine itself, but how it renders
I am trying to get product viz for diamond jewelry, and a lot of the files submitted to us (by the customer) do not have diamond cuts below the diamonds (as can be seen in the image). This means that when rendering, the "metal" below the diamond shows through the diamond. Earlier when I had experimented with VRay, I was able to do a setting, which would allow for the metal to not be seen below the diamond (maybe something to do with transmission rays, not sure though). Or is there some setting which allows me to "prioritize" the diamond material over the metal's material.
Either way, is there a setting/workaround which would allow me to use the client's files as it is and not have the diamond "show through" the intersecting metal?
Thanks in advance!
Thanks in advance!
