How to add UVmapping to a planks created using Geometry Nodes
Posted: Thu May 12, 2022 9:41 am
by jorari71
Hello.
I'm trying to learn how to use Geometry Nodes combined with Luxcore and I took a Geometry Nodes for generating a floor with parallel and straight planks.
The problem is that I don't know how to apply my UVmaps to each plank once I have my wood texture.
I know how to create tone variations for each instance and how to rotate the unique texture, generating in this way a lot of planks with random variations, which is awesome.
The issue arrives when I try to apply all this to Geometry Nodes.
How can I transfer my texture with the randomness I want to each of the geon Nodes planks I've created?
I have this for now and as you can see each different tone doesn't apply per plank and the texture can't be seen...Still.
Some advice?
Thanks in advance.
Re: How to add UVmapping to a planks created using Geometry Nodes
Posted: Wed Feb 15, 2023 3:17 pm
by FloridaJo
Not sure if you found a way, but you can convert geonode objects to mesh objects then proceed from there.
Just hit Ctrl + A > Visual Geometry to Mesh.
