Could not locate required Intel Oidn files
Posted: Tue Mar 01, 2022 6:05 pm
by TAO
Try to build windows from source with the latest source and I face this issue, I can download and add the Odin Files but I assume it should be automatically downloaded by the build script so I post it to be sure.
CMake Error at CMakeLists.txt:126 (MESSAGE):
--> Could not locate required Intel Oidn files - Please check
Re: Could not locate required Intel Oidn files
Posted: Tue Mar 01, 2022 8:10 pm
by acasta69
TAO wrote: Tue Mar 01, 2022 6:05 pm
It's working flawlessly here:
-- Intel OIDN support: enabled
Compilazione completata.
Avvisi: 0
Errori: 0
Tempo trascorso 00:10:52.96
Are you sure you are using the latest version of WindowsCompileDeps?
Deps are automatically downloaded by the build script only if a "WindowsCompileDeps" directory is not found, otherwise the existing is used.
Posted: Wed Mar 02, 2022 12:40 pm
by TAO
acasta69 wrote: Tue Mar 01, 2022 8:10 pm
Avvisi: 0
Errori: 0
maybe I'm on the wrong repo or I should do a clean build, I will delete all the Deps and try one more time to see if it will solve the issue for me and I will get back to you.
Posted: Wed Mar 02, 2022 7:48 pm
by TAO
Sorry, it was my mistake WindowsCompile was on the wrong branch called "oiio_renamed" after I merged the master repo everything was fine and the source compiled with no Deps issue.
