Problem with correct Exposure in Luxcore
Posted: Tue Jan 18, 2022 9:45 pm
by syhrdrjrt
Unfortunately i can not upload this scene because it is too big.
These two scenes have the identical background, are both lit by a sun with physically correct brightness, have a similar material applied to the scene, no clamping and have the same number of light bounces.
CYCLES:
In Cycles I use an addon to set the camera to a suitable exposure for a sunny day :
This addon changes the exposure in the Color Management tab:
blender exp.jpg (12.33 KiB) Viewed 11686 times
LUXCORE:
If I then try to render this scene with the same exposure setting using Luxcore I get this completely different result:
(apparently Luxcore cannot process this setting correctly, or at least not in the same way cylces does?)
if I then set this exposure in the Color Managment tab back to zero and instead use the Luxcore Camera Tonemapper with the same camera settings for a sunny day, I get this result:
Which is still very different from the result in cycles. Why?
Re: Problem with correct Exposure in Luxcore
Posted: Wed Jan 19, 2022 12:56 pm
When you h1ve too large scene file you make a simplified version of it with all settings and upload it.
Posted: Wed Jan 19, 2022 3:02 pm
by kintuX
Also note
If you're simply switching between Cycles & LuxCore, not everything works OoB > Cycles Scene Reader (features),
so inconsistencies are expected.
Posted: Wed Jan 19, 2022 4:17 pm
by syhrdrjrt
No, I adjusted the settings and materials for Luxcore
Posted: Thu Jan 20, 2022 10:38 pm
by kintuX
Oh, also, looks like you have some stuff there which is visible in rendering but not in viewport. :?
