Will python 2.7 work with latest(2.6) release?
Posted: Wed Dec 29, 2021 12:30 am
by opoppopopp
I need
Python 3.9 to import pyluxcore.pyd, am I right ? (latest version
luxcorerender-v2.6-win64-sdk.zip)
So luxcore render
NOT support Python 2.7?
now it is "missing dll" when I try to import pyluxcore, but luxcoreui.exe work fine!
the document page seems says Python 2 also work.
python3 pyluxcoretools.zip
# or
python pyluxcoretools.zip
BUT the LuxCoreRender / WindowsCompile repository also says:
NOTE:
...If needed, you can specify the preferred version among from 3.6 to 3.10, e.g.:
.\cmake-build-x64.bat /python36
Working on some legacy old code that need Python 2......
Thanks!
Re: Will python 2.7 work with latest(2.6) release?
Posted: Wed Dec 29, 2021 1:33 pm
opoppopopp wrote: Wed Dec 29, 2021 12:30 am
# or
I think that's meant for OSs where "python" means python 3, e.g. arch linux.
Posted: Wed Dec 29, 2021 3:01 pm
I need
Yes, the binaries are compiled to work with Blender (and Python version used by Blender) so the latest binaries require Python 3.x.
I need
So luxcore render
LuxCore was working fine with Python v2.x and it may still work however you need to compile the binaries on your own (with Python v2.x instead of v3.x) and try.
Posted: Wed Dec 29, 2021 3:23 pm
by opoppopopp
Dade wrote: Wed Dec 29, 2021 3:01 pm
Thanks!
Glad to hear that you confirm python 2 works.
So can I use the same guide document and script to compile against 2.7 on windows?
Because seems the parameters are all 3.x
Posted: Wed Dec 29, 2021 5:08 pm
opoppopopp wrote: Wed Dec 29, 2021 3:23 pm
You may have to edit the compiling script:
https://github.com/LuxCoreRender/Window ... 64.bat#L18
As I wrote, it should work but you may have to add some hack here and there: it is a while we don't Python v2.x anymore.
Posted: Wed Dec 29, 2021 5:17 pm
by acasta69
We have removed the support for Python 2.7 months ago (end of official support has been 01-01-2020), however, as Dade said, it should still be possible to compile LuxCore with Python 2.7.
First of all, you need to restore the required Python 2.7 dependencies (Python includes, Boost.Python and Boost.NumPy) in the LuxCore dependency tree.
The easiest way to get them is to download an old version of the binary dependencies:
https://github.com/LuxCoreRender/Window ... _v2.6_1.7z
Unzip the downloaded file, then copy everything related to Python 2.7 to the WindowsCompileDeps directory you are currently using to build LuxCore (the "include\Python27" folder and the following files in x64\Release\lib: libboost_numpy27-vc141-mt-x64-1_72.lib, libboost_python27-vc141-mt-x64-1_72.lib, python27.dll, python27.lib).
You also need to restore support for the "/python27" switch in "cmake-build-x64.bat".
It should be straightforward, just add this line
if /i "%1" EQU "/python27" set PYTHON_VERSION=27
near the similar lines 33-37 for the other python versions.
Now it should be possible to build:
I hope I did not forget anything. I'll try to give support in case of problems...
Posted: Sat Jan 01, 2022 7:52 pm
by opoppopopp
Am I need python to compile?
the doc says no, unless I need “create-standalone.bat” and "pyluxcoretools"
I just trying to first compile an most recent version
(after that, try to bring back Pyhon27 support follow your steps above)
I am at a fresh system,
even no python on this machine
only "clone repos" and install "2019 Build Tools for Visual Studio"
but
/cmake-only gives:
-- Could NOT find Boost (missing: Boost_INCLUDE_DIR thread program_options filesystem serialization iostreams regex system python39 chrono serialization numpy39) (Required is at least version "1.56.0")
-- Re-trying with link static = OFF
from the log of cmake, seem other lib/includes was found without problem.
Maybe I still need python, for a compile?
Posted: Sun Jan 02, 2022 8:26 am
by acasta69
opoppopopp wrote: Sat Jan 01, 2022 7:52 pm
No, Python is not needed to compile LuxCore.
Are you able to compile following the standard instructions at WindowsCompile/readme.txt? That should work flawlessly and produce a build for Python 3.9.
Then following the steps above you should be able to compile also for Python 2.7.
Can you please post the full command line and output from cmake-build-x64.bat /cmake-only
Posted: Sun Jan 02, 2022 9:15 am
by opoppopopp
You are totally correct, the error above is because I use Windows 7 SP1, missing some update, thus cause cmake generate some error.
build for Python 3.9 is flawlessly!
And I made it, success build pylucore.pyd against python 2.7! your step is precise!
Thank you!
BTW. what is the lowest version number of Numpy, that still working with lux?
(pyluxcore_venv) C:\Users\Workstation\Downloads\luxcorerender-v2.6-win64-sdk>python
Python 2.7.17 (v2.7.17:c2f86d86e6, Oct 19 2019, 21:01:17) [MSC v.1500 64 bit (AMD64)] on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> exit()
(pyluxcore_venv) C:\Users\Workstation\Downloads\luxcorerender-v2.6-win64-sdk>python samples\pyluxcoredemo\pyluxcoredemo.py
LuxCore 2.6
Strands example...
[SDL][0.000] Define ImageMap: NamedObject
[SDL][0.000] Material definition: whitematte
[SDL][0.000] Camera type: perspective
Posted: Sun Jan 02, 2022 1:15 pm
by acasta69
opoppopopp wrote: Sun Jan 02, 2022 9:15 am
Try to install the latest version that still supports Python 2.7, it should work.
I don't recall exactly which version I used for LuxCore deps and Python 2.7, probably 1.15.4, so any newer version should work fine.
EDIT: For Python 2.7 it was actually NumPy 1.15.4.
