Reuse Material Nodes between Blend files?
Posted: Fri Dec 17, 2021 10:56 pm
So it seems there's no way to reuse node setups between blend files. I tried appending the node tree setup and then adding a "pointer" inside the node editor, but it does nothing, shows a black material instead. Using Luxcore 2.5 with Blender 2.92
