Irradiance Contour
Posted: Mon Oct 04, 2021 12:50 pm
by JuandeLara
Hello all,
I have been looking into trying to visually represent lux measurements on a Luxcore render.
I understand from Dade, that one way to do it is with false colour setting, and trying to match each colour to the real-world values using a photometer. I think this could work, but I would need to test it at some point.
For a more reliable approach I though of working with the values for the Irradiance contour lines (see this post: viewtopic.php?f=4&t=2142). Here I found the Irradiance test.blend, but I cannot replicate the same effect.
The main difference is I am using a sun value at 1.0 gain. And there are a number of values in the camera irradiance feature, which I cannot understand mathematically, namely:
  • Scale
    Range
    Steps
    Grid size
I have been playing around with these values, but since I don't fully understand them, particularly when applied to a sun I am getting something like this: https://bit.ly/2YoGN39
Would really appreciate any input on this workflow and figuring out the best setup for the Irradiance paths.
Re: Irradiance Contour
Posted: Mon Oct 04, 2021 3:31 pm
The sun is a LOOOOOT more powerful than artificial light sources so you need to increase the range of the contour plugin by a looooot.
With the following parameters:
film.imagepipelines.000.3.type = "CONTOUR_LINES"
film.imagepipelines.000.3.range = 3500000
film.imagepipelines.000.3.scale = 179
film.imagepipelines.000.3.steps = 32
film.imagepipelines.000.3.zerogridsize = 16
you obtain this result:
Note: producing the above result takes quite some time due to noise. At the start, the lines are all mixed but the will clean over time.
There also a couple of stuff you should disable because they are not useful for your task (or may introduce artifacts in your results): bloom and denoiser.
You can save the plain rendering in EXR format and than check the pixel values to have an idea of the range of values.
Posted: Tue Oct 05, 2021 8:13 am
by JuandeLara
Thanks Dade,
It does work, you are right, it just takes a lot of time.
If I change the steps from 32 to say 128, does it mean I will get more of the contour lines? I mean at a shorter interval on the image?
I am quite curious to understand which function is the one you used to obtain the scale as 179, and range 3,500,000.
Posted: Tue Oct 05, 2021 10:09 am
JuandeLara wrote: Tue Oct 05, 2021 8:13 am If I change the steps from 32 to say 128, does it mean I will get more of the contour lines? I mean at a shorter interval on the image?
Yes.
JuandeLara wrote: Tue Oct 05, 2021 8:13 am I am quite curious to understand which function is the one you used to obtain the scale as 179, and range 3,500,000.
It is conversion factor to match Radiance results: https://github.com/LuxCoreRender/LuxCor ... es.cpp#L36
// Scale should be set to 179.0: the value of 179 lm/w is the standard luminous
// efficacy of equal energy white light that is defined and used by Radiance. It
// can be used here to produce the same output of Radiance.
// More information here: http://www.radiance-online.org/pipermai ... 03616.html
Posted: Wed Oct 06, 2021 6:26 am
by JuandeLara
Great thank you Dade!
