new FELIX + luxcore tests
An more complex scene created using FELIX + Luxcore. 8 minutes rendering.
Re: new FELIX + luxcore tests
daros wrote: Thu Jul 08, 2021 11:01 pm An more complex scene created using FELIX + Luxcore. 8 minutes rendering.
weldone, amazingly done.
One more 30 minutes test. It contains 28 different light types and about 400 light sources, 20M unique polygons, about 12.000 instances, 800 megapixel textures.
and here at 10 minutes rendering.
patro
Post by patro »
daros wrote: Mon Jul 12, 2021 11:40 pm One more 30 minutes test. It contains 28 different light types and about 400 light sources, 20M unique polygons, about 12.000 instances, 800 megapixel textures.
woooow!!
looks like an airport bakery :P i want one of the pastries.
Great job. The glass from the is greish, needs some settings editing.
the 10 minutes rendering of course is good for preview.
It is unbelievable how good this render engine is.
You can build a scene like this without any kind of trick. Just throw stuff to the scene and go. !00% linear behavior, no surprises.
X patro, which glass exactly? the one in the foreground? It looks heavy in some way right?
Here the same sccene with some materials slightly improved.
One more test.
Materials and lighting has to be finetuned.
daros wrote: Thu Jul 15, 2021 9:00 am One more test.
You moving too fast dude, nice.
patro
Post by patro »
daros wrote: Wed Jul 14, 2021 6:46 pm It is unbelievable how good this render engine is.
the glass in foreground which stores the pastries slices :)
patro
Post by patro »
patro wrote: Thu Jul 15, 2021 3:14 pm
the glass in foreground which stores the pastries slices :) it is greish, should not be colorless, or green depending on the glass type.
miekaer
Post by miekaer »
Looks very nice!
