compilation problems
Posted: Fri Jul 02, 2021 9:00 am
Hi Guys. I wan to ask what is the correct procedure to update dependencies before compilation. I was compiling sdk ./build-64-sse2 LuxCore-sdk but there were errors about not compatible OpenImageIO. It looks that you have updated it, and my headers were out of date. I've have tried many tricks (removing distfiles dir, runign scripg first_run.sh). At the end I removed everything and started from begging. In that case the compilation has finished successfully. But it was very slow as I had to recompile everything. So my question is. What is the correct way to do that?
