linux compile error
BruceXu
linux compile error
Post by BruceXu »
mv: cannot stat 'libOpenImageIO.a': No such file or directory
!!! openimageio installation failed
Do I need to download a libOpenImageIO.a file separately?
Re: linux compile error
I think the static openimageio has been used in the current build and you do not need to do anything about it except download and build the project with all dependencies that are required on the platform you work on and that should be all.
Perhaps you missed a part in downloading and setting up Linux dependencies during the build time.
Which version you are using for it?
BruceXu wrote: Thu Jun 17, 2021 8:47 am mv: cannot stat 'libOpenImageIO.a': No such file or directory
Are you following the procedure described here (https://github.com/LuxCoreRender/LinuxCompile) ?
BruceXu
Post by BruceXu »
Dade wrote: Thu Jun 17, 2021 9:18 am
Thank you for your reply
1. I want to compile C on Linux, but because of the network problem, I can only download the B file manually
2. Comment out the following code
#if [ $? != 0 ] ; then
# echo " * Resume downloading $FILE"
# wget -c -O $DIST/$FILE $URL
# verify_hash $HASH "$DIST/$FILE"
# if [ $? != 0 ] ; then
# echo " !!! Hash mismatch for $FILE"
# exit 1
# fi
#fi
3. Then run. / first_ run.sh
BruceXu
Post by BruceXu »
e, i am back
I've had some more problems:
LinuxCompile-master/target-64-sse2/lib/libOpenImageIOBase.a(webpinput.cpp.o): In function `OpenImageIO_v2_2::webp_pvt::WebpInput::close()':
webpinput.cpp:(.text+0x16): undefined reference to `WebPDemuxReleaseIterator'
webpinput.cpp:(.text+0x22): undefined reference to `WebPDemuxDelete'
BruceXu
Post by BruceXu »
ok,I've solved the problem.
Use the following metho,remove the libwebp-dev:
https://github.com/LuxCoreRender/LinuxCompile/issues/1
