LuxcoreRender v2.5 error w/ Lenovo W530 Quardro K2000M -
Posted: Sat Jun 12, 2021 8:54 pm
I am having problem getting LuxCoreRender to work with a w530 laptop fit with a Quadro K2000M .
Is there a way to force it to run in CPU mode?
LuxCoreUI v2.5 (LuxCore demo: http://www.luxcorerender.org)
Parsing LuxRender SDL file...
[SDL][5.672] Define ImageMap: NamedObject
[SDL][5.672] Material definition: ground
[SDL][5.672] Material definition: FreeCADMaterial_Lux_Pocket
[SDL][5.672] Camera type: perspective
[SDL][5.672] Camera position: Point[62.6413, -44.1115, -53.4127]
[SDL][5.672] Camera target: Point[17.7166, 1.94607, 31.4638]
[SDL][5.672] Camera clipping plane disabled
[SDL][5.672] Scene objects count: 2
[SDL][5.672] Light definition: LUXCORE_LIGHT_0_SUN2
[SDL][5.672] Light definition: LUXCORE_LIGHT_0_SKY2
[LuxCore][5.703] Configuration:
[LuxCore][5.703] opencl.platform.index = -1
[LuxCore][5.703] opencl.cpu.use = 0
[LuxCore][5.703] opencl.gpu.use = 1
[LuxCore][5.703] renderengine.type = "BIDIRCPU"
[LuxCore][5.703] sampler.type = "SOBOL"
[LuxCore][5.703] film.filter.type = "MITCHELL_SS"
[LuxCore][5.719] accelerator.instances.enable = 0
[LuxCore][5.719] path.maxdepth = 16
[LuxCore][5.719] light.maxdepth = 16
[LuxCore][5.719] film.filter.xwidth = 1
[LuxCore][5.719] film.filter.ywidth = 1
[LuxCore][5.719] film.filter.mitchell.B = 0.3333333
[LuxCore][5.719] film.filter.mitchell.C = 0.3333333
[LuxCore][5.719] film.width = 960
[LuxCore][5.719] film.height = 540
[LuxCore][5.719] film.imagepipeline.0.type = "TONEMAP_AUTOLINEAR"
[LuxCore][5.719] film.imagepipeline.1.type = "GAMMA_CORRECTION"
[LuxCore][5.719] film.imagepipeline.1.value = 2.2
[LuxCore][5.719] batch.halttime = 0
[LuxCore][5.719] batch.haltspp = 0
[LuxCore][5.719] File Name Resolver Configuration:
[LuxCore][5.719] .
[LuxCore][5.719] C:/Users/TestFile
[SDL][5.719] Camera type: perspective
[SDL][5.719] Camera position: Point[62.6413, -44.1115, -53.4127]
[SDL][5.719] Camera target: Point[17.7166, 1.94607, 31.4638]
[SDL][5.719] Camera clipping plane disabled
Film size adjusted: 960x540 (Frame buffer size: 960x540)
RenderConfig has cached kernels: True
[LuxCore][5.719] Film resolution: 960x540
[SDL][5.719] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][5.719] Image pipeline: film.imagepipeline
[SDL][5.719] Image pipeline step 0: TONEMAP_AUTOLINEAR
[SDL][5.719] Image pipeline step 1: GAMMA_CORRECTION
[LuxRays][5.719] OpenCL support: enabled
[LuxRays][5.750] OpenCL Platform 0: Intel(R) OpenCL
[LuxRays][5.765] OpenCL Platform 1: NVIDIA CUDA
[LuxRays][5.765] CUDA support: enabled
[LuxRays][5.765] CUDA support: available
[LuxRays][5.765] CUDA driver version: 9.10
[LuxRays][5.765] CUDA device count: 1
[LuxRays][5.765] Optix support: not available
[LuxRays][5.765] Device 0 name: Native
[LuxRays][5.765] Device 0 type: NATIVE_THREAD
[LuxRays][5.765] Device 0 compute units: 1
[LuxRays][5.765] Device 0 preferred float vector width: 4
[LuxRays][5.765] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][5.765] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][5.765] Device 0 has out of core memory support: 0
[LuxRays][5.765] Device 1 name: Intel(R) Core(TM) i7-3820QM CPU @ 2.70GHz
[LuxRays][5.765] Device 1 type: OPENCL_CPU
[LuxRays][5.765] Device 1 compute units: 8
[LuxRays][5.765] Device 1 preferred float vector width: 8
[LuxRays][5.765] Device 1 max allocable memory: 7758MBytes
[LuxRays][5.765] Device 1 max allocable memory block size: 1939MBytes
[LuxRays][5.765] Device 1 has out of core memory support: 0
[LuxRays][5.765] Device 2 name: Intel(R) HD Graphics 4000
[LuxRays][5.765] Device 2 type: OPENCL_GPU
[LuxRays][5.765] Device 2 compute units: 16
[LuxRays][5.765] Device 2 preferred float vector width: 1
[LuxRays][5.765] Device 2 max allocable memory: 1400MBytes
[LuxRays][5.765] Device 2 max allocable memory block size: 350MBytes
[LuxRays][5.765] Device 2 has out of core memory support: 0
[LuxRays][5.765] Device 3 name: Quadro K2000M
[LuxRays][5.765] Device 3 type: OPENCL_GPU
[LuxRays][5.781] Device 3 compute units: 2
[LuxRays][5.781] Device 3 preferred float vector width: 1
[LuxRays][5.781] Device 3 max allocable memory: 2048MBytes
[LuxRays][5.781] Device 3 max allocable memory block size: 512MBytes
[LuxRays][5.781] Device 3 has out of core memory support: 0
[LuxRays][5.781] Device 4 name: Quadro K2000M
[LuxRays][5.781] Device 4 type: CUDA_GPU
[LuxRays][5.781] Device 4 compute units: 192
[LuxRays][5.781] Device 4 preferred float vector width: 1
[LuxRays][5.781] Device 4 max allocable memory: 2048MBytes
[LuxRays][5.781] Device 4 max allocable memory block size: 17592186044415MBytes
[LuxRays][5.781] Device 4 has out of core memory support: 1
[LuxRays][5.781] Device 4 CUDA compute capability: 3.0
[LuxRays][5.781] Creating 8 intersection device(s)
[LuxRays][5.781] Allocating intersection device 0: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 1: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][5.781] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxCore][5.781] Configuring 8 CPU render threads
[LuxRays][5.781] Preprocessing DataSet
[LuxRays][5.781] Total vertex count: 410
[LuxRays][5.781] Total triangle count: 390
[LuxRays][5.781] Preprocessing DataSet done
[LuxRays][5.781] Adding DataSet accelerator: EMBREE
[LuxRays][5.797] EmbreeAccel build time: 16ms
[LuxCore][5.875] Film hardware image pipeline
[LuxCore][5.937] Film hardware device used: Quadro K2000M CUDAIntersect (Type: CUDA_GPU)
[LuxRays][5.937] [Device Quadro K2000M CUDAIntersect] IMAGEPIPELINE buffer size: 6075Kbytes
[LuxRays][5.937] [Device Quadro K2000M CUDAIntersect] Merge buffer size: 8100Kbytes
[LuxRays][5.937] [MergeSampleBuffersOCL] Compiler options: -D LUXRAYS_OPENCL_KERNEL -D SLG_OPENCL_KERNEL -D LUXRAYS_CUDA_DEVICE -D LUXRAYS_OS_WINDOWS --use_fast_math
[LuxRays][5.937] [MergeSampleBuffersOCL] Compiling kernels
[LuxCore][5.969] [Quadro K2000M CUDAIntersect] Memory used for hardware image pipeline: 14175Kbytes
RUNTIME ERROR: CUDA driver API error CUDA_ERROR_INVALID_PTX (code: 218, file:D:\a\1\Luxcore\src\luxrays\utils\cuda.cpp, line: 247): a PTX JIT compilation failed
