Page 1 of 2
PyLuxCoreTools - Segmentation Fault
Posted: Mon May 03, 2021 4:33 pm
by d1nuc0m
I was trying to use PyLuxCoreTools (
from 2.5 release) on Kubuntu 20.04.x, with Python 3.8.5.
I extracted the folder and tried to run both
python3 pyluxcoretools.zip and
sudo python3 pyluxcoretools.zip.
The only result is "Segmentation fault".
Re: PyLuxCoreTools - Segmentation Fault
Posted: Mon May 03, 2021 6:46 pm
Releases are compiled with Python v3.7 (because of Blender), it is likely to not work with v3.8. I know for sure that opposite: binaries compiled with v3.8 doesn't work with v3.7.
Posted: Wed May 05, 2021 4:17 pm
by d1nuc0m
Dade wrote: Mon May 03, 2021 6:46 pm
Ok, I have tried to use Python 3.7.10 with
pyenv (PySide2 installed), but I still get a segmentation fault.
This happens both with Python 3.7.10 as shell-specific Python version and both with 3.7.10 set as global Python version.
Posted: Wed May 05, 2021 4:44 pm
I assume you have PySide related problem, does "python3 pyluxcoretools.zip help" work ?
Posted: Wed May 05, 2021 6:04 pm
by d1nuc0m
Dade wrote: Wed May 05, 2021 4:44 pm
Just tried, it looks like it works, the output is:
usage: pyluxcoretools.zip [commandToExecute]
PyLuxCoreTool
positional arguments:
commandToExecute help, console, merge, netconsole, netconsoleui, netnode or
netnodeui
Meanwhile, also tried
sudo python3 pyluxcoretools.zip, but still gives segmentation fault.
By the way, I have installed PySide2, as PySide install is not possible on Python 3.7.x (it fails with the following error:
only these python versions are supported: [(2, 6), (2, 7), (3, 2), (3, 3), (3, 4)])
Posted: Wed May 05, 2021 7:02 pm
You can use all pyluxcoretools command line functionalities (i.e. pretty much everything). Due to the lack of PySide, you can not use anything requiring a GUI.
"python3 pyluxcoretools.zip" just open a windows with few options: if you are lacking PySide, it should print an error and it does on my Ubuntu. It looks more like you have something messed up with Python (i.e. it is probably trying to run some wrong version of the PySide binaries).
Posted: Wed May 05, 2021 9:40 pm
by d1nuc0m
Dade wrote: Wed May 05, 2021 7:02 pm
Ok, I also tried on another machine (Artix Linux), this is what I did after installing pyenv:
$ pyenv shell 3.7.10
# Check if I'm using the correct tools
$ python3 --version
Python 3.7.10
$ pip --version
pip 20.1.1 from /home/user/.pyenv/versions/3.7.10/lib/python3.7/site-packages/pip (python 3.7)
# Running PyLuxCore
$ python3 pyluxcoretools.zip
ImportError: numpy.core.multiarray failed to import
ImportError: numpy.core.umath failed to import
File "pyluxcoretools.zip/pyluxcoretools/pyluxcoremenu/cmd.py", line 25, in <module>
ModuleNotFoundError: No module named 'PySide'
During handling of the above exception, another exception occurred:
File "/home/user/.pyenv/versions/3.7.10/lib/python3.7/runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "/home/user/.pyenv/versions/3.7.10/lib/python3.7/runpy.py", line 85, in _run_code
exec(code, run_globals)
File "pyluxcoretools.zip/__main__.py", line 73, in <module>
File "pyluxcoretools.zip/pyluxcoretools/pyluxcoremenu/cmd.py", line 30, in <module>
commands that have no complete_ method.
ModuleNotFoundError: No module named 'PySide2'
# Installing required modules
$ pip install PySide2 numpy
Successfully installed PySide2-5.15.2 numpy-1.20.2 shiboken2-5.15.2
#PyLuxCoreTools
QApplication: invalid style override 'gtk2' passed, ignoring it.
Available styles: Windows, Fusion
Segmentation fault
$ sudo python3 pyluxcoretools.zip
Segmentation fault
What I have not understood is, in theory should I use PySide or PySide2? Because using PySide on Python 3.7.x is not possible.
The highest Python version supported by PySide is 3.4.x, EOL as of 2019, and PySide itself requires Qt 4.x, EOL as of 2015 (trying to use 3.4.10 with PySide has turned into a mess of unmet dependencies and software removed from repos because obsolete).
There is a port of PySide to Qt 5.x, but PyLuxcoreTools seem not to recognise it (tried in another environment):
$ pip install pyside6 numpy
Successfully installed pyside6-6.0.4 shiboken6-6.0.4
I would advice dropping PySide definitely in favor of PySide2 or PySide6
Posted: Wed May 05, 2021 10:58 pm
It looks like you are missing numpy too.
The code was written first for PySide than we moved to PySide2. I don't remember if it is still compatible with old PySide(1), it was for some time (we supported both).
Short version: use PySide2.
Posted: Thu May 06, 2021 9:24 am
by d1nuc0m
Dade wrote: Wed May 05, 2021 10:58 pm
Yes, if you scroll down, I then installed numpy & PySide2, then it gives segmentation fault:
Segmentation fault
Segmentation fault
I was asking about PySide(1) because as you can see there also was an error related to missing PySide(1)
Posted: Thu May 06, 2021 10:10 am
Like I wrote before, you can try to track a stack trace with gdb but, by definition, a Python application can not throw a segmentation fault so you have something broken in your installation.
