Page 2 of 2
Re: Brazilian Liquor
Posted: Thu Apr 22, 2021 11:50 am
by JulianoLisboa
Sharlybg wrote: Thu Apr 22, 2021 7:46 am
JulianoLisboa wrote: Thu Apr 22, 2021 12:21 am
Sharlybg wrote: Wed Apr 21, 2021 6:56 pm A lot better. ;)
Can I see the shader node of both the glass cup and bottles ?
Can you also check normal orientation on the glass cup ?
Do you have shadow color applied at maximum white value on the glass cup ?
Hello, follow the link to download the file.
https://drive.google.com/file/d/1V1I3he ... sp=sharing
Acces denied ;)
Sorry.
Posted: Fri Apr 23, 2021 7:15 pm
by TAO
Much better, now it's great.
Posted: Fri Apr 23, 2021 7:44 pm
by JulianoLisboa
Thank you, but I am waiting for Sharlybg's comments, so I think it will get even better. He must have downloaded the file.
Posted: Fri Apr 23, 2021 8:35 pm
JulianoLisboa wrote: Fri Apr 23, 2021 7:44 pm Thank you, but I am waiting for Sharlybg's comments, so I think it will get even better. He must have downloaded the file.
Just have few minute to investigate the file a bit :
1__ You should work at real world scale with Luxcore to avoid starnge behaviour. Your bottle is 6Meter high here
2__ There is not to much challenging thing in the scene ( not like here : https://youtu.be/R2-u3YNJbHQ ) so Shadow color to white is a bit overkill almost switch off all nice caustic. So default for all is good here.
3__ The liquid mesh inside the bottle have normal inverted.
4__ You can imrove lighting by smoothing plane light edge like in this tutorial for a more natural blending look :
https://youtu.be/32Ojuidbc7k?t=155
Hope it help a bit.
Posted: Fri Apr 23, 2021 8:39 pm
by JulianoLisboa
Thank you my friend .... I will follow your directions
Posted: Sat Apr 24, 2021 1:18 am
by JulianoLisboa
Thanks to everyone who helped me, follow the final image.
Posted: Sat Apr 24, 2021 7:20 am
Couldn'd imagine it will look like that at the end well done.
Posted: Sat Apr 24, 2021 7:41 am
by AndreasResch
Much better than the initial version - especially the poured glass. One little thing. The label looks a bit dark now (especially the lower part). Maybe adding a little frontal/side light back in can fix that. Not as much as in the original version though.
Posted: Mon Apr 26, 2021 12:27 am
by JulianoLisboa
AndreasResch wrote: Sat Apr 24, 2021 7:41 am Much better than the initial version - especially the poured glass. One little thing. The label looks a bit dark now (especially the lower part). Maybe adding a little frontal/side light back in can fix that. Not as much as in the original version though.
Thank you friend, yes the observation proceeds, every time I look I think that the image is finished I find something to fix. About the label I wanted to look more dramatic, but it really got darker than necessary.
Posted: Mon Apr 26, 2021 8:50 am
by TAO
Great job.
