Mac blendluxcore
Posted: Sat Apr 17, 2021 2:56 am
Now that blender has released an ARM version, will there be luxcore ARM release for blender?
I own a MacBook Air, M1, 16 GB. I own a Mac Mini, latest Intel version from mid 2020. Therefore I could and want to learn compiling LuxCore on both Apple Mac systems. Compiling LuxCore on Windows 10 Pro was quite easy with just a few traps only - at least in 2019.u3dreal wrote: Fri Aug 13, 2021 8:07 pm I have made many tries to do so ... but compiling all the deps and luxcore for ARM does not seem to be so trivial on an x86_64 machine.
Everything that goes into luxcore will have to be crosscompiled.
I do not have an Arm Mac... that of course would make things a lot easier though compiling deps will be a challenge.
As far as I know GitHub / azure does not yet support ARM hosts.
Thank you for your answer.u3dreal wrote: Tue Aug 17, 2021 11:18 pm OK you can follow this guide.
https://www.wiki.luxcorerender.org/Comp ... _10.13_.2B
But anyhow. Good luck
-DCMAKE_OSX_ARCHITECTURES=arm64;x86_64Code: Select all
Compiling for M1 macOS with TBB and ISPC
First you'll need to build and install TBB. Grab the source from the TBB Github and build and install it with CMake. For TBB, use the CMake command below. It's also recommended to set an install prefix to install it locally, -DCMAKE_INSTALL_PREFIX=<path to install>
$ mkdir build && cd build
$ cmake -DCMAKE_BUILD_TYPE=Release \
-DCMAKE_CXX_OSX_DEPLOYMENT_TARGET_FLAG=-mmacosx-version-min=11 \
-DCMAKE_C_OSX_DEPLOYMENT_TARGET_FLAG=-mmacosx-version-min=11 \
-DTBB_STRICT=OFF \
-DTBB_TEST=OFF \
$ make install
For ISPC support you'll need to build ISPC, either from the fork https://github.com/Twinklebear/ispc enabling the macOS + arm/neon target, or from the main repo if the pull request https://github.com/ispc/ispc/pull/1943 has been merged. ISPC should be built using their provided build script by running scripts/build.sh from the root directory of the ISPC repo. On M1 you can pass -j 8 to use all 8 cores when building ISPC. The ISPC compiler will be installed under <ispc repo>/install/bin/, which you'll want to add to your path.
Finally, you can build Embree. If you're building with ISPC support, you'll also pass -DEMBREE_ISPC_SUPPORT=ON, If you have GLFW installed you can also set -DEMBREE_TUTORIALS_GLFW=ON to build the interactive tutorials. It's also recommended to set an install prefix to install embree locally, -DCMAKE_INSTALL_PREFIX=<path to install>
$ cmake \
-DEMBREE_ARM=ON \
-DEMBREE_IOS=ON \
-DEMBREE_TASKING_SYSTEM=TBB \
-DEMBREE_TUTORIALS=ON \
-DEMBREE_RAY_PACKETS=ON \
-DEMBREE_MAX_ISA=AVX2 \
-DEMBREE_NEON_AVX2_EMULATION=ON \
-DAS_MAC=ON \
-DCMAKE_OSX_ARCHITECTURES=arm64 \
-DCMAKE_OSX_DEPLOYMENT_TARGET=11 \
-DTBB_DIR=<tbb install dir>/lib/cmake/TBB/ \
-DEMBREE_ISPC_SUPPORT=ON \
$ make install
To avoid warnings about failing to set thread affinity with TBB, run the tutorials with --set_affinity 0, and when creating the embree device in your code, pass set_affinity=0 to rtcNewDevice:
RTCDevice device = rtcNewDevice("set_affinity=0");
Build monolithc embree with TBB(experimental)
EMBREE_USE_EMBEDDED_TBB=On builds the embree with local tbb. (Dowload TBB and extract it to thrid_party/tbb. Adding TBB as a submodule was removed as original Intel Embree did)
This will enable building monolithic embree library with single cmake build procedure. (Would make embree build with TBB support for emerging architecures and cross compiling easier)
-DEMBREE_TASKING_SYSTEM=Internal \
-DEMBREE_USE_EMBEDDED_TBB=On \
