Re: [CRASHING] Simples scene crashing on RTX2070
Posted: Fri Apr 16, 2021 9:31 am
I may have been able to replicate the problem, I'm looking into it.
B.Y.O.B., I'm also getting a BlendLuxCore error if I try to export the scene from Blender:
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/export/caches/object_cache.py", line 261, in first_run
duplis = instances[obj.original.as_pointer()]
KeyError: 139641619472904
During handling of the above exception, another exception occurred:
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/export/material.py", line 43, in convert
active_output.export(exporter, depsgraph, props, luxcore_name)
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/nodes/materials/output.py", line 162, in export
exported_name = self.inputs["Material"].export(exporter, depsgraph, props, luxcore_name)
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/nodes/sockets.py", line 88, in export
return link.from_node.export(exporter, depsgraph, props, luxcore_name, link.from_socket)
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/nodes/base.py", line 102, in export
luxcore_name = self.sub_export(exporter, depsgraph, props, luxcore_name, output_socket)
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/nodes/materials/glossytranslucent.py", line 117, in sub_export
"kd": self.inputs["Diffuse Color"].export(exporter, depsgraph, props),
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/nodes/textures/hsv.py", line 19, in sub_export
"texture": self.inputs["Color"].export(exporter, depsgraph, props),
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/nodes/textures/imagemap.py", line 173, in sub_export
filepath = ImageExporter.export(self.image, self.image_user, exporter.scene)
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/export/image.py", line 58, in export
return cls._save_to_temp_file(image)
File "/home/david/.config/blender/2.92/scripts/addons/BlendLuxCore/export/image.py", line 45, in _save_to_temp_file
image.filepath_raw = orig_filepath
AttributeError: Writing to ID classes in this context is not allowed: Plant_01_2K_Base_Color.png, Image datablock, error setting Image.filepath_raw
