Glossy transluscent and grass
Posted: Mon May 14, 2018 1:36 pm
by wasd
I have a question about glossy translucent material. I am trying to make grass, but wiki has very little information on how to use this material. And what troubles me the most is that part of grass just disappear. The first screen is glossy material and the second is glossy translucent.
Re: Glossy transluscent and grass
Posted: Mon May 14, 2018 3:48 pm
wasd wrote: Mon May 14, 2018 1:36 pm
Too much transmission ? Have you tried to use a darker color ?
Can you upload the scene?
Posted: Mon May 14, 2018 3:59 pm
by wasd
Dade wrote: Mon May 14, 2018 3:48 pm
The same with pitch black.
Posted: Mon May 14, 2018 4:03 pm
by wasd
B.Y.O.B. wrote: Mon May 14, 2018 3:48 pm
Yep.
And two more shots with a little different angle of view. One has grass disappeared, other has not.
If it matters, HDRI is green point park 8k from hdrihaven.
Posted: Mon May 14, 2018 4:30 pm
When you turn around it with viewport render running, you can see it flicker.
Weird problem.
Posted: Mon May 14, 2018 4:38 pm
B.Y.O.B. wrote: Mon May 14, 2018 4:30 pm
Weird problem.
Scene size
Max. path depth
Posted: Mon May 14, 2018 4:43 pm
by wasd
It also depends on normals direction. It's either left side, or right side which disappear (depending on normals direction). Left/right side of the screen, not the side of the bush.
Posted: Mon May 14, 2018 5:46 pm
I have tried different epsilon settings, or deleting the (large) ground plane, but it does not help.
Posted: Mon May 14, 2018 6:54 pm
wasd wrote: Mon May 14, 2018 4:43 pm
Oh, aren't they solid ? There may be a mess with inside/outside volumes. Glossy translucent material is like glass, it assumes to enclose a volume and has different behaviors when a ray is going from outside to inside and vice versa. I think this is the source of your problem.
Have you tried to use normal glossy + transparency ? Transparency is a property common to all materials. It also a lot faster to render than glossy translucent material.
