Denoise trouble
Posted: Wed Mar 17, 2021 6:40 pm
by Eltorro313
when i do render my test scene, i see nice picture, but after denoise, it become worst. i tried many different settings and i attachet the bes what i could get
pls help me to find out what the problem.
And I dont know how to upload testscene......So, i cant send blend file here, irs to large, so i attached another scene, with absolutely same settings, houp it helps.
after denoise picture loocks blured
Re: Denoise trouble
Posted: Thu Mar 18, 2021 7:41 am
by AndreasResch
The denoised version will always look more "blurry". But unless this happens in the area where the noise is, that's usually OK. If the blur effect is too harsh, you might need more samples in the base rendering.
I would try to use the Compositor and save the un-denoised image as well as the denoised one out and blend them by either using an overall opacity or specific masks. For a still rendering that might be fast enough to do.
Re: Denoise trouble
Posted: Thu Mar 18, 2021 8:26 am
by Eltorro313
so fore example, same picture in Cycles , same amount of samples 500..... so why in luxcore denoise destroy image, when its mus be helpful?
you see in attachment? it almost realistic, and only 500 samples. I looke pictures in lucore galary, no one is blure like that
Re: Denoise trouble
Posted: Thu Mar 18, 2021 8:36 am
by zeealpal
Did you make the LuxCore materials for your scene, or use the Cycles conversion?
It would be good to see the raw output of the LuxCore render. Also the uploaded untitled.blend does not match your scene, was that intentional?
Re: Denoise trouble
Posted: Thu Mar 18, 2021 8:38 am
by AndreasResch
This seems to be more than a simple denoise issue. There's something else going on.
Re: Denoise trouble
Posted: Thu Mar 18, 2021 11:17 am
by Eltorro313
Yes, I did LuxCore marerials
Re: Denoise trouble
Posted: Thu Mar 18, 2021 11:59 am
by Eltorro313
So what i figured out, if i use Cycles nodes inLuxCore, everything good, once i turn tu Luxcore nodes, or start new project in Luxcore enviroment with luxcore materials, after denoise, picture become blured...... wery strange
Re: Denoise trouble
Posted: Thu Mar 18, 2021 12:31 pm
by AndreasResch
In the two images that you've shown above, it's not only a case of one being blurred. There are a lot more issues going on. Textures are missing, lights are different, it looks darker. That's not just a denoise issue.
I also tried the BLEND file that you posted in the initial post and it looks perfectly fine on my PC. The noise rendering has a bunch of noise and fireflies and the denoised one looks clean and OK.
I guess we need some better comparisons where just the blurry issue is shown. Otherwise the case is too confusing and at least I don't know where to start tackling the problem.
Re: Denoise trouble
Posted: Thu Mar 18, 2021 2:35 pm
by Eltorro313
i have another scene for comparing, not all materials is set yet but enough for comparing
both attached
the lust one is Cycles
Re: Denoise trouble
Posted: Thu Mar 18, 2021 2:55 pm
by AndreasResch
I'm not an expert on denoising, but the first shot has A LOT of noise in it. 248 samples is quite low I guess. You might also want to look into some of the Cache options. But I will have to pass this on to the architectural experts.
Maybe you will find something in those two Youtube channels ...
https://www.youtube.com/c/djtutorialscgi/videos
https://www.youtube.com/c/DRAVIASTUDIO/videos
