RTX2080Ti - OpenCL faster than CUDA / Optix?
Posted: Wed Mar 03, 2021 8:14 pm
by juangea
I just tested a scene we are working on, by mistake I used the OpenCL configuration before, with the latest BlendLuxCore 2.5, downloaded today, and this is the result:
OpenCL - 2:34:
CUDA / Optix ( I assume it is using Optix because it's an RTX card) - 2:43 :
Both renders with the kernel already compiled.
What's going on here?
Re: RTX2080Ti - OpenCL faster than CUDA / Optix?
Posted: Wed Mar 03, 2021 10:48 pm
What GPU are you using ?
Posted: Thu Mar 04, 2021 7:17 am
Dade wrote: Wed Mar 03, 2021 10:48 pm
Rtx 2080ti i think. It is in The title.
Posted: Thu Mar 04, 2021 9:30 am
juangea wrote: Wed Mar 03, 2021 8:14 pm
It is not normal. The rendering time is very short so it may something in the pre-processing too. How is the reported samples/sec ? Do is happen for a 10mins rendering too ? Do you have a test scene ?
Posted: Thu Mar 04, 2021 10:20 am
by juangea
Hey Dade.
I can send you this scene privately, it's from a project but if it's in private I have no trouble.
I have to deliver this morning, I'll try to do some tests to answer your questions.
I'll try to speak you on Discord to send you the scene, today, but a bit later
Thanks!
Posted: Thu Mar 04, 2021 10:24 am
You can export the scene in LuxCore format in CLAY mode and send me just the .cfg/.scn/etc. files zipped (may be it is small enough at that point for a forum PM). It should be enough.
Posted: Thu Mar 04, 2021 10:32 am
by juangea
I prefer to send you the whole scene with all the shaders and lighting, with everything, but I can send it to you with a link from a PM here, no problem, as soon as we deliver the project I'll prepare it
Posted: Mon Mar 22, 2021 12:47 pm
by VoithHog
AMD or NVIDIA GPU ? Version of LuxCore used ?
First of all check if you have a working OpenCL installation by running LuxMark i.e. if it doesnt work, there is a problem with OpenCL drivers.
Posted: Mon Mar 22, 2021 12:59 pm
by juangea
I said all that information in the first thread.
And drivers are correctly working in both systems.
Keep in mind that OpenCL is being FASTER than CUDA, not SLOWER (which is what should be expected with a 2080Ti)
I have to upload the scene yet, I had no time basically
