Viewport render issue
Luximage
Post by Luximage »
With the latest blendluxcore daily version when i render in the viewport and then terminate the render view the cpu usage gets stuck at 100%.
My system win 10, blender 2.91.2, nvidia gpu.
Re: Viewport render issue
Luximage wrote: Fri Feb 12, 2021 10:37 am With the latest blendluxcore daily version when i render in the viewport and then terminate the render view the cpu usage gets stuck at 100%.
Blend file to reproduce the issue :?:
I have also encountered this, but didn't find a way to reproduce it reliably yet.
Luximage
Post by Luximage »
I also cannot reproduce it now.
I did a windows update, i don't know if that counts for something.
Same here. Can't reliably reproduce it, but sometimes either memory leaks or it just crashes when I change a setting in an Image pipeline.
I only found a way to prevent it, while working long hours - turn interactivity off more often.
I was thinking of having an experimental time bomb switch to kill it after a a while of non-stop working with it. Something alike an old GPU "watch-dog".
But as I'm ignorant with coding, I can only do it manually.
kintuX wrote: Fri Feb 12, 2021 3:38 pm Same here. Can't reliably reproduce it, but sometimes either memory leaks or it just crashes when I change a setting in an Image pipeline.
What exactly I'm facing while using interactive scenes, especially with big HDRI or PNG textures.
Sometimes getting slow, sometimes crash and other times noting happen. But the only way to be sure I'm working without issues is to turn off interactive every a few changes so be sure the memory will be released.
I think because of caching the maps while changing gamma and other stuff that will cause memory leak somehow.
It will only happen on GPU, many times it's ok but it will happen occasionally.
Screen.mp4
(1.05 MiB) Downloaded 790 times
6700k
16GB ram
Vga geforce730 4GB Nvidia
Screen-Capture02.mp4
(2.84 MiB) Downloaded 744 times
9900k
32GB ram
VGA 1080 Nvidia 8GB
I already report the issue on github too.
The problem mentioned in the OP and experienced by me does not involve any crashes.
So KintuX and TAO, you might be describing different issues.
B.Y.O.B. wrote: Fri Feb 12, 2021 6:46 pm The problem mentioned in the OP and experienced by me does not involve any crashes.
I apologize for polluting the thread.
Indeed, it's a different issue than what's being described here (CPU usage stuck @ 100% when terminating viewport). It happened recently, but I 'killed' a process and can't reproduce it. Will try to keep it in mind and pay more attention in future.
8-)
Luximage
Post by Luximage »
I managed to reproduce the problem, it happens when i hit z choose material preview then choose rendered viewport and finally choose solid viewport, the cpu usage remains at 100%.
viewport issue.blend
(838.56 KiB) Downloaded 816 times
Luximage wrote: Tue Feb 16, 2021 6:58 pm I managed to reproduce the problem, it happens when i hit z choose material preview then choose rendered viewport and finally choose solid viewport, the cpu usage remains at 100%.
Nice, I tested it 3 times and it has reproduced the issue each time. Thanks, that helps a lot.
