Volume Intersect Problem
Posted: Sat Nov 21, 2020 11:58 am
by DionXein
I found strange behaviour while using smoke in blender and rendering it with Lux. Here u can see example scene: smoke domain intersect marble dog figure and enlight dog volume. Figure is smoke collision effector and doesn't really intersect smoke. If change priority value of volumes - it can only cut a part of dog but nothing else.
To see difference just disable smoke domain rendering in outliner
Blender 2.9, Lux 2.5 beta1
Scene for testing:
https://drive.google.com/file/d/1e3GifT ... NPTnX0Y_U/
Re: Volume Intersect Problem
Posted: Tue Nov 24, 2020 3:07 pm
by Luximage
Interesting scene, the spotlight seems to be the problem, it illuminates the smoke and visually cuts the dog in half.
Posted: Tue Nov 24, 2020 3:34 pm
by DionXein
Okay, seems no one knows where problem is. May be anyone knows how to render smoke in different pass with shading from original objects and combine it?
Just make all other objects holdout?
Posted: Tue Nov 24, 2020 3:35 pm
by DionXein
Luximage wrote: Tue Nov 24, 2020 3:07 pm
Spotlight appears the problem, not cause it.
Posted: Thu Nov 26, 2020 3:50 pm
Posted: Fri Nov 27, 2020 2:34 pm
by Luximage
Dade wrote: Thu Nov 26, 2020 3:50 pm
I downloaded the latest daily build and i think the problem remains.
Posted: Fri Nov 27, 2020 3:31 pm
Luximage wrote: Fri Nov 27, 2020 2:34 pm
The scene you posted works fine here, check if you have correctly updated BlendLuxCore.
Posted: Fri Nov 27, 2020 3:57 pm
I can also still reproduce the problem with the latest sources (from auto build on Windows, self-compiled on Linux) with this scene:
https://github.com/LuxCoreRender/BlendL ... issues/601 (after moving the domain cube a bit to the left).
Posted: Sat Nov 28, 2020 5:21 am
by DionXein
I check last build (16 hours ago) and problems still there
Posted: Tue Dec 01, 2020 1:47 pm
It is working fine here:
and it wasn't before (the posted scene doesn't include smoke data so I'm using an homogeneous volume both cases).
What kind of result do you get ?
