Cannot build SDK for Visual Studio 2017 / 2019 (luxparse.y problem ?)
Posted: Fri Nov 13, 2020 3:58 pm
Hello friends!
I am trying to install the SDK on my Windows machine so I can experiment / learn and get started on building a LuxCoreRender application.
I'm following the exact steps on the guide here: https://github.com/LuxCoreRender/WindowsCompile
After calling
And then
.. it gets to work. It starts to process everything but at a certain point, quits the installation with a 'fatal error'.
This is what it says:
I'll attach it as an image that is perhaps more readable:
Any ideas please?
After calling
cd C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompileCode: Select all
.\cmake-build-x64.batThis is what it says:
CustomBuild:
[BISON][lux_parser] Building parser with bison 2.7
19>CustomBuild:
20>CustomBuild:
C:/Rendering/LuxCoreRender/luxcorerender/LuxCore/src/luxcore/luxparser/luxparse.y:20.20-41: error: syntax error, unexpected {...}
19>CustomBuild:
19>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(209,5): error MSB6006: "cmd.exe" exited with code 1. [C:\Rendering\LuxCore
Render\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj]
19>Done Building Project "C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj" (default targets) -- FAILED.
16>Done Building Project "C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj.metaproj" (default targets) -- FAILED.
20>C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\Common7\IDE\VC\VCTargets\Microsoft.CppCommon.targets(209,5): error MSB6006: "cmd.exe" exited with code 1. [C:\Rendering\LuxCore
Render\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj]
20>Done Building Project "C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj" (default targets) -- FAILED.
11>Done Building Project "C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj.metaproj" (default targets) -- FAILED.
1>Done Building Project "C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" (default targets) -- FAILED.
Build FAILED.
"C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\LuxRays.sln" (default target) (1) ->
"C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj.metaproj" (default target) (16) ->
"C:\Rendering\LuxCoreRender\luxcor[img][/img]erender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj" (default target) (19) ->
(CustomBuild target) ->
reRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\pyluxcore.vcxproj]
"C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj.metaproj" (default target) (11) ->
"C:\Rendering\LuxCoreRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj" (default target) (20) ->
reRender\luxcorerender\WindowsCompile\Build_CMake\LuxCore\src\luxcore\luxcore.vcxproj]
0 Warning(s)
2 Error(s)
Time Elapsed 00:02:43.98
--- FATAL ERROR RUNNING CMAKE ---I'll attach it as an image that is perhaps more readable:
Any ideas please?
