Python Set object Material Help
Posted: Sat Oct 03, 2020 12:19 pm
by MentalArray
Hi so im wanting to this in this order
  • Add a new material
    Set material to an existing object
    Remove old material from scene
i did find this code but its not the same in the fact that it changes a current material
# Begin scene editing
		self.session.BeginSceneEdit()
		# Edit the material
		self.scene.Parse(pyluxcore.Properties().
			Set(pyluxcore.Property("scene.materials.shell.type", ["mirror"])).
			Set(pyluxcore.Property("scene.materials.shell.kr", [0.75, 0.75, 0.75])))
		# To remove unreferenced constant textures defined implicitely
		self.scene.RemoveUnusedTextures()
		# To remove all unreferenced image maps (note: the order of call does matter)
		self.scene.RemoveUnusedImageMaps()
		# End scene editing
		self.session.EndSceneEdit()
i have been trying to use the command
UpdateObjectMaterial()
but getting error RuntimeError : Unknown object in Scene::UpdateObjectMaterial():
what should i be passing as the object name if i have an object described below
scene.objects.27342762485360.material = "BlankMat00012419016618936"
scene.objects.27342762485360.ply = scenes/Fracball_LuxCore/Ball.ply
scene.objects.27342762485360.camerainvisible = 0
scene.objects.27342762485360.id = 1795813475
scene.objects.27342762485360.appliedtransformation = 1 0 0 0 0 1 0 0 0 0 1 0 0 0 0 1
thank you for any help in advance
Re: Python Set object Material Help
Posted: Sat Oct 03, 2020 3:40 pm
MentalArray wrote: Sat Oct 03, 2020 12:19 pm i have been trying to use the command
"27342762485360" is the object name to pass to Scene::UpdateObjectMaterial() (what were you using ?).
P.S. like the material name is "shell" in your code fragment.
Posted: Sat Oct 03, 2020 3:53 pm
by MentalArray
hi yes i did use that and i used the mat name and get the error material now :(
this is running in c# python net 3.7
 session.BeginSceneEdit();
 	//this line adds the material correctly
        sceneProps.SetFromString("scene.materials.whitematte.type = matte" + Environment.NewLine +
        "scene.materials.whitematte.kd = 0.75 0.0 0.0" + Environment.NewLine +
        "scene.materials.whitematte.id = 10101010");
        //this line throws the error (Python.Runtime.PythonException: 'RuntimeError : Unknown material in  Scene::UpdateObjectMaterial(): whitematte')
          scene.UpdateObjectMaterial("27342762485360", "whitematte");
session.EndSceneEdit();
Posted: Sat Oct 03, 2020 4:09 pm
MentalArray wrote: Sat Oct 03, 2020 3:53 pm hi yes i did use that and i used the mat name and get the error material now :(
Did you forget to post some line of code code ? You are not parsing the sceneProps. It should be something like:
        "scene.materials.whitematte.id = 10101010" + Environment.NewLine);
        // MISSING THIS:
	scene.Parse(sceneProps)
You are also missing a "+ Environment.NewLine" from the last "scene.materials.whitematte.id" property (but as far as I remember this shouldn't be a problem anymore).
Posted: Sat Oct 03, 2020 4:18 pm
by MentalArray
yes i have tried that latest code
                                    scene.Parse(sceneProps);
umm still get error :(
Posted: Sun Oct 04, 2020 12:47 am
by MentalArray
ok got it working finally :)
just needed to add
scene.Parse(pyluxcore.Properties(sceneProps));
and it worked....
