Normal maps straight up don't work with GPU Hybrid Tracing
Posted: Thu Oct 01, 2020 6:45 pm
So for a while, ever since Lux 2.4 came out actually, I've been getting an error in my renderings where materials just straight up don't render, it's just black.
After doing some testing I've found that materials will render as long as I'm not rendering with GPU Hybrid tracing, all other rendering on CPU, GPU, Path, Bidir, CPU Hybrid, works just fine.
I've also found that it's the normal maps that's likely causing the material blackout, using the displacement map or even the blue channel of the normal map with a bump node works just fine. Heck, even just plugging in the normal map as an RGB image into the material still renders without blacking out. So it's only when the "Normal Map" is checked in the image does the GPU Hybrid tracing fail.
Is there anything I can do to fix this, or is this a bug with 2.4? Normal maps worked just fine in 2.1-2.3 and blender 2.79-2.83 and I wouldn't be surprised if normal maps in 2.3 still worked in 2.90
Also, I'm rendering on an Ryzen 7 3700X and RX 570 with the latest AMD Radeon Drivers (20.9.2)
Here are some images form my testing, I'm more than willing to share more images and even the blend file if asked
GPU Path Tracing w/ Normal Map:
GPU Hybrid Tracing w/o Normal Map:
GPU Hybrid Tracing w/ Normal Map:
GPU Hybrid Tracing w/ Normal Map as RGB Image ("Normal Map" unchecked):
Thank you for the help!
