Pointiness falloff
Posted: Thu Apr 19, 2018 7:57 pm
by Egert_Kanep
Is it possible to control pointiness falloff? Right now it seems that multiplier slider only controls it's strength not size.
Re: Pointiness falloff
Posted: Thu Apr 19, 2018 8:18 pm
You can use a colorramp (aka Band node in BlendLuxCore).
It is in the utils -> band category in the material node editor.
Just slide one of the offsets to the left/right and you have non-linear falloff.
But maybe I misunderstand what exactly you want?
Posted: Fri Apr 20, 2018 8:06 am
by Egert_Kanep
What I am trying to do is to make pointiness affect bigger area. In the attached photo I want to make pointiness go further down the slopes, but using band only increases contrast.
Posted: Fri Apr 20, 2018 10:18 pm
by Racleborg
Would adding a maths node give more control over the pointlessness effect, or possibly use Mapping to help position the effect. Sorry, I'm a bit new to this myself!
Posted: Sat Apr 21, 2018 6:45 am
Pointiness calculation is a mesh preprocess step.
The surface curvature is evaluated and stored in the vertex alpha channel.
The preprocessing has no parameters:
https://wiki.luxcorerender.org/LuxCore_ ... pointiness
So if you can't extend the radius with the band node, you're out of luck.
It is a crude thing to begin with (because it depends on the mesh density).
A much better solution would be a texture that is evaluated at render time (however this would also be much harder to implement).
Something like V-Ray Dirt:
https://docs.chaosgroup.com/display/VRA ... C+VRayDirt
