Different HDRi for Lightning and Camera?
Posted: Wed Sep 02, 2020 7:42 am
by HoppyHopp
Hey,
Is it possible in LuxCore to use 1 HDRI for rhe lightning and annother one for the viewport/camera?
In Cycles i can use the Lightpath-Node for that, but i read that this node will not come for LuxCore.
Re: Different HDRi for Lightning and Camera?
Posted: Wed Sep 02, 2020 8:42 am
use your hdri normally and set your camera to film transparent in camera propertie. then in tonemapper below camera setting check bckgrd image.
Posted: Wed Sep 02, 2020 8:53 am
by HoppyHopp
Hmm, that doesent rlly work like i want.
But thx for the help.
Posted: Wed Sep 02, 2020 8:15 pm
HoppyHopp wrote: Wed Sep 02, 2020 7:42 am
Hey,
Nope, it isn't possible.
Posted: Thu Sep 03, 2020 8:51 am
by HoppyHopp
I found a workaround not the best or efficient but it gets the job done.
Posted: Thu Sep 03, 2020 10:26 am
HoppyHopp wrote: Thu Sep 03, 2020 8:51 am
Textured Dome mesh.
Posted: Thu Sep 03, 2020 10:28 am
Would be great to share so others can learn about it.
Sharlybg wrote: Thu Sep 03, 2020 10:26 am
Textured Dome mesh.
But that doesn't have the right "light intensity". From what I gathered you can't have emission w/o influencing other geo. As mentioned before Rayswitcher, Light Path node or a dedicated Environment Light setup (like most other engines do) would help and solve the issue.
eg RadeonPro Render's Env. Light controls:
I'm also interested in what's been done here to tackle this problem.
Posted: Thu Sep 03, 2020 1:16 pm
by HoppyHopp
As i said it is rlly dirty and cheap.
Just render with the "Light-HDRI" and transparent Film. And then change to the "View-HDRI" and render without any objects.
Combine both in post. Ofc in some cases in can cause problem with reflections but im fine with that, better than nothing. ^^
Light HDRI:
Combined transparent film render width no object "View-HDRI" render:
