Hair Strand Step Bug
Posted: Fri Aug 21, 2020 10:02 pm
Hello there!
I find strange bug while trying to transport scene from Cycles to LuxCore. All materials and meshes work fine, except hair. It gives me error notify (pic 1). In other scene simple hair works pretty fine. Sometimes changing values in hair render and viewport menu (pic 2) let me render hair in viewport . But I didn't find any dependency between these moments. In blend file hair cause problems are disabled, just try to enable-disable it.
Error text:
Python argument types in
Property.__init__(Property, str, tuple)
did not match C++ signature:
__init__(class boost::python::api::object, class boost::python::str, class boost::python::list)
__init__(struct _object * __ptr64, class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >, class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)
__init__(struct _object * __ptr64, class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >, double)
__init__(struct _object * __ptr64, class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >, int)
__init__(struct _object * __ptr64, class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >, bool)
__init__(struct _object * __ptr64, class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >)
Link to blend file:
https://drive.google.com/file/d/1j0hGD9 ... sp=sharing
Error text:
Link to blend file:
