Edges
Posted: Mon Apr 16, 2018 6:34 pm
by david57
I was trying out the new addon. I was checking out to see if the background image to
the camera worked and it does work. Thanks.
I noticed something never had seen before. There are thin dark lines around the edges.
I noticed them more after I came from outside but now they are dimmer.
I eyes are getting used to the light inside the house.
Re: Edges
Posted: Mon Apr 16, 2018 7:33 pm
I don't clearly see the problem in your image but for your description it seems something that could be fixed with pre-multiplied alpha
Re: Edges
Posted: Mon Apr 16, 2018 7:35 pm
Maybe more white wall will make it a bit more obvious.
Re: Edges
Posted: Mon Apr 16, 2018 10:46 pm
by david57
Where can I find the option: pre-multiplied alpha ?
Can not find it.
Re: Edges
Posted: Tue Apr 17, 2018 7:08 am
david57 wrote: Mon Apr 16, 2018 10:46 pm
Can not find it.
It is something the addon enables/disables internally when transparent background is enabled/disabled.
It should already work.
Can you upload the scene so I can check?
Re: Edges
Posted: Tue Apr 17, 2018 7:22 pm
by david57
Re: Edges
Posted: Sat Apr 21, 2018 9:03 am
I had a look at your scene yesterday.
I can get it to work correctly in the Blender compositor.
But the imagepipline plugin always shows dark edges, no matter if I disable/enable the premultiply alpha plugin.
See
https://github.com/LuxCoreRender/BlendL ... issues/136
Re: Edges
Posted: Sat Apr 21, 2018 10:37 pm
by david57
Thanks,
It might not be a serious problem.
It might be something rarely seen.
