Page 4 of 8
Re: LuxCore v2.1 proposed features
Posted: Sun Apr 29, 2018 12:41 pm
I updated the list in the first post. It should include everything. I will create a poll in a couple of days.
Posted: Sun Apr 29, 2018 4:27 pm
Posted: Sun Apr 29, 2018 4:29 pm
Posted: Sun Apr 29, 2018 4:36 pm
Guys i'm thinking about a feature don't know if it's possible but let's see:
i'm thinking about a possibility to use many deferent texture for only one shader with some option like " Apply by loose parts/face/position" and "randomize".
They call it
Multi/Sub-Object Material in 3dsmax :
how i magine it but sure it can be diferent :
Posted: Sun Apr 29, 2018 7:12 pm
How the texture mixer work ? According what rules ?
Posted: Sun Apr 29, 2018 11:12 pm
by oldladyfear
i would love to see roughness added to architectural glass, in order to do more realistic SSS shaders - using the translucent shaders isn't very accurate, and causes much longer render times compared to using architectural glass, textured transmission & a heavy scattering volume.
Currently there's a workaround i've found by connecting a glossy coat to an architectural glass shader (the roughness from the glossy coat seems to override the architectural glass reflections if the transmission isn't black), but it would be nice to not require workarounds like that.
Posted: Mon Apr 30, 2018 9:20 am
Add normal auto-smooth and architectural glass roughness.
Posted: Mon Apr 30, 2018 1:19 pm
Dade wrote: ↑Sun Apr 29, 2018 7:12 pm
After your question i've take more time to think about the mechanics behind ("also found that my first idea was not that good"). The most possible and correct way will be to have it like a sort of advance
MIX MATERIAL.
Super MIX MATERIAL
# 1 It should be able to support more than 2 material
# 2 the material will be mixed by blender fonction like :
" loose part " " position "
Posted: Mon Apr 30, 2018 3:12 pm
Sharlybg wrote: ↑Mon Apr 30, 2018 1:19 pm
MIX MATERIAL.
Super MIX MATERIAL
Your explanation is even more vague than the original post
Posted: Mon Apr 30, 2018 4:41 pm
by heverton
Dade wrote: ↑Mon Apr 30, 2018 3:12 pm
MIX MATERIAL.
Super MIX MATERIAL
I think it behaves like this:
Think in a modeled wood floor/planks/and so;
You plug 2 or more textures (Could have a + button to add more then 2);
Randomize by loose geometry and you have only 1 of these textures per loose geometry of the object.
