SDS Caustics in a nutshell
Posted: Mon Jul 27, 2020 2:34 pm
by igmar75
first of all, thank you for Luxrender. It is invaluable.
I'm experimenting with specular-diffuse-specular caustics with Path Tracing and PhotonGI Caustic Cache. After some search and tests (maybe not enough..) I'm still confused about the minimal configuration required to see caustics through mirrors; attached, a not-working example. Is there someone able to give a very basic list of to-do in order to have the SDS caustics working with PhotonGI Caustic Cache?
Thank you!
Igmar
Blender v2.83.3
LuxCore 2.4
Win 10 64bit
Re: SDS Caustics in a nutshell
Posted: Mon Jul 27, 2020 2:53 pm
You have to make your twos cube renderable in the collection.
blend
Caustics_through_mirror.blend
(1006.9 KiB) Downloaded 691 times
Posted: Mon Jul 27, 2020 3:21 pm
by igmar75
The caustic cannot be seen in the 3D Viewport?
Posted: Mon Jul 27, 2020 3:51 pm
igmar75 wrote: Mon Jul 27, 2020 3:21 pm The caustic cannot be seen in the 3D Viewport?
SDS caustic is generated by caustic cache.It is a cached solution. only light traced caustic can be seen in the viewport because they are not cached but directly computed.
Posted: Mon Jul 27, 2020 4:06 pm
All caches currently in LuxCore are only computed for final renders.
It does not really make sense to compute them in the viewport because they would need to be re-computed on every geometry or material change, and cache computation is usually too expensive for real-time feedback.
Posted: Mon Jul 27, 2020 4:07 pm
by igmar75
Thank you!
Igmar
Posted: Tue Jul 28, 2020 9:00 am
by igmar75
1) I continued experimenting, and I found a possible cause of confusion: even if I leave checked the "Caustic Light Cache" file (under "Persistence"), it is not updated! To update it, I have to change the cache file name; unflagging and flagging again the checkbox will not work. Attached you can find the test file. I think you should try to reproduce this behaviour on your machine..
2) Moreover, I noticed that I have to put the Roughness (of the big cylinder) to a value >0.25 to have it collecting caustics. This is not in agreement with the Glossiness Thresholds, whose value is 0.05.
Any idea?
