Use for material's absorption color
Posted: Mon Jul 27, 2020 6:30 am
by MetinSeven
What's the common use of a LuxCoreRender material's Absorption functions? It seems that it only changes the surface color, or can you also achieve some SSS effect with it, as opposed to adding a Volume node?
Thanks!
Re: Use for material's absorption color
Posted: Mon Jul 27, 2020 8:53 am
It simulates absorption in the glossy coating, which means it's angle-dependent: the shallower the angle between camera and surface, the stronger the effect. I think I've seen this effect in pottery glaze, but I'm not totally sure. It can also be used for car paint.
It does not compute any SSS.
Posted: Mon Jul 27, 2020 10:00 am
by MetinSeven
Thanks for the clarification! So if I understand it correctly absorption on a material level is more like a coating, not sub-surface absorption for a SSS / translucency effect. A volume node is needed for that.
Posted: Mon Jul 27, 2020 10:04 am
MetinSeven wrote: Mon Jul 27, 2020 10:00 am
Yes, in Lux, materials always describe only the surface, the inside of an object is defined by the volume definition.
Posted: Mon Jul 27, 2020 10:11 am
by MetinSeven
Thanks!
