AttributeError: 'LuxCoreScene' object has no attribute 'opencl'
Posted: Tue Jun 16, 2020 10:27 pm
Crashs with default or any other scene using openCL in any way.
BlendLuxCore 2.4alpha0 registered (with pyluxcore 2.4alpha0)
BlendLuxCore/commit/066bde9cde2a8549194442d3309fabbd2435b480
LuxCore/commit/240dd579d2fc7a89a21ac648af413377f8e4e59e
With current versions and the ones from the last two or three weeks
, rendering is only possible if GPU/openCL is not used for any lux job (rendering and tone-mapping).
For what reason ever BlendLuxCore calls an openCL related 'function' even with all user interface easy accessible openCL related properties disabled.
There is also at least one call short after rendering on CPU only started.
The moment render engine is switched from CPU to CPU BlendLuxCore calls several openCL related 'functions', leading to error messages continously logged.
Starting rendering (menu or F12) crashes Blender immediately!
Exported scene crashes LuxCoreUI with a short delay without further notice.
Session started in 0.1 s
File "C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.82\scripts\addons\BlendLuxCore\ui\render_performance.py", line 45, in draw_header
opencl = context.scene.luxcore.opencl
Recommended clamp value: 0.5752207951808475
[LuxCore][109.297] Noise estimation: first pass
[LuxCore][156.375] Noise estimation: Error mean = 0.00752252
[LuxCore][212.797] Noise estimation: Error mean = 0.00424715
[LuxCore][267.563] Noise estimation: Error mean = 0.00269058
[LuxCore][328.219] Noise estimation: Error mean = 0.00204711
[LuxCore][388.860] Noise estimation: Error mean = 0.00163634
[LuxCore][449.516] Noise estimation: Error mean = 0.00135031
[LuxCore][469.531] Samples per pixel 100%, rendering done.
[Engine/Final] Finished rendering layer "View Layer"Starting rendering (menu or F12) crashes Blender immediately!
Read prefs: C:\Users\Michael\AppData\Roaming\Blender Foundation\Blender\2.82\config\userpref.blend
found bundled python: C:\Program Files\Blender Foundation\Blender 2.82\2.82\python
Warning: property 'release_confirm' not found in keymap item 'OperatorProperties'
[Engine/Final] Rendering layer "View Layer"
[Exporter] Creating session
[SDL][60.188] Camera type: perspective
[SDL][60.188] Camera position: Point[8.11889, -6.92579, 4.88831]
[SDL][60.188] Camera target: Point[7.42818, -6.27471, 4.57364]
[SDL][60.188] Camera clipping plane disabled
[SDL][60.188] Material definition: Matte__Rot2497769616712
[SDL][60.188] Material definition: Matte__Green2497769620744
[SDL][60.188] Scene objects count: 2
[SDL][60.188] Light definition: 2497770379928
[SDL][60.188] Light definition: __WORLD_BACKGROUND_LIGHT__
[LuxCore][60.203] Configuration:
[LuxCore][60.203] path.pathdepth.total = 7
[LuxCore][60.203] path.pathdepth.diffuse = 5
[LuxCore][60.203] path.pathdepth.glossy = 5
[LuxCore][60.203] path.pathdepth.specular = 6
[LuxCore][60.203] path.hybridbackforward.enable = 0
[LuxCore][60.203] path.hybridbackforward.partition = 0.80000000000000004
[LuxCore][60.203] path.hybridbackforward.glossinessthreshold = 0.048999998718500137
[LuxCore][60.203] film.noiseestimation.warmup = 8
[LuxCore][60.203] film.noiseestimation.step = 32
[LuxCore][60.203] sampler.sobol.adaptive.strength = 0.89999997615814209
[LuxCore][60.203] sampler.sobol.bucketsize = 16
[LuxCore][60.203] sampler.sobol.tilesize = 16
[LuxCore][60.203] sampler.sobol.supersampling = 1
[LuxCore][60.203] sampler.sobol.overlapping = 1
[LuxCore][60.203] renderengine.type = "PATHCPU"
[LuxCore][60.203] sampler.type = "SOBOL"
[LuxCore][60.203] film.width = 1920
[LuxCore][60.203] film.height = 1080
[LuxCore][60.203] film.filter.type = "BLACKMANHARRIS"
[LuxCore][60.203] film.filter.width = 1.5
[LuxCore][60.203] lightstrategy.type = "LOG_POWER"
[LuxCore][60.203] scene.epsilon.min = 9.9999997473787516e-06
[LuxCore][60.203] scene.epsilon.max = 0.10000000149011612
[LuxCore][60.203] film.opencl.enable = 0
[LuxCore][60.203] path.forceblackbackground.enable = 0
[LuxCore][60.203] renderengine.seed = 1
[LuxCore][60.203] film.outputs.0.type = "RGB_IMAGEPIPELINE"
[LuxCore][60.203] film.outputs.0.index = 0
[LuxCore][60.203] film.outputs.0.filename = "RGB_IMAGEPIPELINE_0.png"
[LuxCore][60.203] film.outputs.1.type = "RGB_IMAGEPIPELINE"
[LuxCore][60.203] film.outputs.1.index = 1
[LuxCore][60.203] film.outputs.1.filename = "RGB_IMAGEPIPELINE_1.png"
[LuxCore][60.203] film.imagepipelines.001.0.type = "NOP"
[LuxCore][60.203] film.imagepipelines.001.1.type = "TONEMAP_LINEAR"
[LuxCore][60.203] film.imagepipelines.001.1.scale = 1
[LuxCore][60.203] film.imagepipelines.001.radiancescales.0.enabled = 1
[LuxCore][60.203] film.imagepipelines.001.radiancescales.0.globalscale = 1
[LuxCore][60.203] film.imagepipelines.001.radiancescales.0.rgbscale = 1 1 1
[LuxCore][60.203] film.imagepipelines.001.2.type = "GAMMA_CORRECTION"
[LuxCore][60.203] film.imagepipelines.001.2.value = 2.2000000000000002
[LuxCore][60.203] film.noiseestimation.index = 1
[LuxCore][60.203] film.imagepipelines.000.0.type = "NOP"
[LuxCore][60.203] film.imagepipelines.000.1.type = "TONEMAP_LINEAR"
[LuxCore][60.203] film.imagepipelines.000.1.scale = 1
[LuxCore][60.203] film.imagepipelines.000.radiancescales.0.enabled = 1
[LuxCore][60.203] film.imagepipelines.000.radiancescales.0.globalscale = 1
[LuxCore][60.203] film.imagepipelines.000.radiancescales.0.rgbscale = 1 1 1
[LuxCore][60.203] batch.haltspp = 256
[LuxCore][60.203] batch.halttime = 0
[LuxCore][60.203] File Name Resolver Configuration:
Export took 0.0 s
[LuxCore][60.203] Film resolution: 1920x1080
[SDL][60.203] Film output definition: RGB_IMAGEPIPELINE [image.png]
[SDL][60.203] Image pipeline: film.imagepipelines.000
[SDL][60.203] Image pipeline step 0: NOP
[SDL][60.203] Image pipeline step 1: TONEMAP_LINEAR
[SDL][60.203] Image pipeline: film.imagepipelines.001
[SDL][60.203] Image pipeline step 2: GAMMA_CORRECTION
[SDL][60.203] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_0.png]
[SDL][60.203] Film output definition: RGB_IMAGEPIPELINE [RGB_IMAGEPIPELINE_1.png]
[LuxRays][60.219] OpenCL support: enabled
[LuxRays][60.219] OpenCL Platform 0: AMD Accelerated Parallel Processing
[LuxRays][60.219] CUDA support: enabled
[LuxRays][60.219] Device 0 name: Native
[LuxRays][60.219] Device 0 type: NATIVE_THREAD
[LuxRays][60.219] Device 0 compute units: 1
[LuxRays][60.219] Device 0 preferred float vector width: 4
[LuxRays][60.219] Device 0 max allocable memory: 17592186044415MBytes
[LuxRays][60.219] Device 0 max allocable memory block size: 17592186044415MBytes
[LuxRays][60.219] Device 0 has out of core memory support: 0
[LuxRays][60.219] Device 1 name: gfx1010
[LuxRays][60.219] Device 1 type: OPENCL_GPU
[LuxRays][60.219] Device 1 compute units: 20
[LuxRays][60.219] Device 1 preferred float vector width: 1
[LuxRays][60.219] Device 1 max allocable memory: 8176MBytes
[LuxRays][60.219] Device 1 max allocable memory block size: 6732MBytes
[LuxRays][60.219] Device 1 has out of core memory support: 0
[LuxRays][60.219] Device 2 name: gfx1010
[LuxRays][60.219] Device 2 type: OPENCL_GPU
[LuxRays][60.219] Device 2 compute units: 20
[LuxRays][60.219] Device 2 preferred float vector width: 1
[LuxRays][60.219] Device 2 max allocable memory: 8176MBytes
[LuxRays][60.219] Device 2 max allocable memory block size: 6732MBytes
[LuxRays][60.219] Device 2 has out of core memory support: 0
[LuxRays][60.219] Creating 8 intersection device(s)
[LuxRays][60.219] Allocating intersection device 0: Native (Type = NATIVE_THREAD)
[LuxRays][60.219] Allocating intersection device 1: Native (Type = NATIVE_THREAD)
[LuxRays][60.219] Allocating intersection device 2: Native (Type = NATIVE_THREAD)
[LuxRays][60.219] Allocating intersection device 3: Native (Type = NATIVE_THREAD)
[LuxRays][60.219] Allocating intersection device 4: Native (Type = NATIVE_THREAD)
[LuxRays][60.219] Allocating intersection device 5: Native (Type = NATIVE_THREAD)
[LuxRays][60.219] Allocating intersection device 6: Native (Type = NATIVE_THREAD)
[LuxRays][60.219] Allocating intersection device 7: Native (Type = NATIVE_THREAD)
[LuxCore][60.219] Configuring 8 CPU render threads
[LuxRays][60.219] Preprocessing DataSet
[LuxRays][60.219] Total vertex count: 48
[LuxRays][60.219] Total triangle count: 24
[LuxRays][60.219] Preprocessing DataSet done
[LuxRays][60.219] Adding DataSet accelerator: EMBREE
[LuxRays][60.219] EmbreeAccel build time: 0ms
AL lib: (EE) ALCmmdevPlayback_mixerProc: Failed to get padding: 0x88890004
